Rafters - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 03:22 PM   #16
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Originally Posted by ecocco1469 View Post
My kitchen was vaulted when I bought house now I wanted to knock wall down between kit n dining room n vault the dining room also to match kit. The rafters in attic sit on outside wall n the joist r still up n also sit on wall. U saying if I remove ceiling joist that my wall will expand out if so then y hasn't that happened to kitchen wall I'm trying to put pics up but I can't figure how to do it from the DIY phone app. Maybe I need to b on computer to show pics?
The reason your vaulted ceiling hasn't come down is it has a ridge beam that is holding the rafters up and keeping your walls from spreading. You can be assured if you take your ceiling joist out without a ridge beam your walls will spread and your roof will sag or come completely down.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-27-2013, 03:50 PM   #17
No I def have a ridge beam going across entire ceiling
ecocco1469 is offline   Reply With Quote
Old 02-27-2013, 03:51 PM   #18
So then it is ok to do the vaulted ceiling since the ridge beam is holding everything up
Old 02-27-2013, 03:53 PM   #19
Rewards Points: 528
the problem is is it a structural ridge beam.
This is why you need an engeneer to determine if what you want to do is fee sable.
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
BigJim (02-27-2013)
Old 02-27-2013, 05:14 PM   #20
GBrackins's Avatar
Rewards Points: 2,108
I'm jumping into this just to reply to this question ..... the reason probably is (can't say for sure because I have not been to your home) that the amount (width) of vaulted ceiling does not exceed the load bearing capacity of your existing ridge. Basically the wider the width of the vaulted ceiling the more load the ridge must carry. You reach a point where what you want (more vaulted ceiling area) and what you have (non-structural ridge) do not work together, that's when you'll have issues.
Hire a local professional engineer that works on residential structures and you'll get it right the first time. Cheap money in the long run.
Sorry for any intrusion ....
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 02-27-2013, 07:05 PM   #21
Good luck!
Thanks for the info. Could I build a new ridge just underneath my existing one of a 2 by 8 or 2 by 10 n add new rafters from ridge all way down to my wall n then add drywall to that. This way in would not b putting dry wall directly on roof rafters n I'd still have vaulted look n have more depth for insulation n air flow
Old 02-27-2013, 07:44 PM   #22
GBrackins's Avatar
could it be done ....... yes
would what you propose work ......... don't know
it takes someone at your home viewing the existing conditions and what you want to do to determine that. since you do not know me or my level of knowledge or experience, if I said "yes" would you anyway??????????
You can "try" lots of things, hiring an engineer will get it done correctly the first time. no wasted money, no wasted time and labor. That's my best recommendation for you.
Good luck!
Gary
Old 02-27-2013, 10:09 PM   #23
AHH, SPANS!!!
Rewards Points: 1,166
most likely the wall you want to take out is holding some of the vaulted ceiling weight and the weight of the flat ceiling too.
hand drive is offline   Reply With Quote
Old 02-28-2013, 07:46 AM   #24
Yes the wall I want to take down is holding up the dining room ceiling. But I'm planning on taken that down n making it vaulted
Old 02-28-2013, 08:08 AM   #25
AHH, SPANS!!!
therein lies the problem. you will need a structural ridge beam spec'd from a qualified structural eng... proper load points, the works.
Building a pergola having issues with "bowing" in rafters. chriscarney Building & Construction 3 06-02-2012 05:53 PM
Furring out existing 2x6 rafters kirylm Building & Construction 27 02-13-2012 11:10 PM
Help attaching 2x12 rafters... bettyb Roofing/Siding 7 02-05-2012 04:57 PM
Insulating 2x4 attic ceiling rafters help needed tseverson Insulation 2 11-01-2011 08:57 PM
checking the rafters joefromcal Carpentry 3 10-01-2010 09:12 AM
