Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-16-2013, 08:29 AM   #1
Rafters
I want to build vaulted ceiling but my rafters r 2 by 6 n I want to make them 2 by 8 or deeper. Could I add 2 by 4 using cleats n make rafters 2 by 10 so I can easily add lights n insulation before drywall. Or will that move n crack or not hold up at all. Or should I just add new 2 by 10 next to old rafters
ecocco1469 is offline   Reply With Quote
Old 02-16-2013, 08:39 AM   #2
Rafters
Go back and add your location to your profile, yes it makes a big differance on questions like this.
Vaulted ceilings look cool but add a lot of issues.
Trying to get the proper amount of insulation up there can be a big problum.
All the heat is going to be going up so the rooms feel colder.
Going to have to redesign the way the roof is kept from spreading.
http://www.energystar.gov/index.cfm?...sulation_table
Old 02-16-2013, 09:49 AM   #3
Rafters
Old 02-16-2013, 10:00 AM   #4
Rafters
That's y I want to make rafters deeper so I can add insulation
Old 02-16-2013, 10:05 AM   #5
Rafters
Someone told me to add 2 by 4 n make it into a 2 by 10 n add insulation n lights but I think that will eventually move in future causing cracks. That's y I was thinking if I butted 2 by 10 next to rafters it will give me enough room for insulation n my light cans.
Old 02-16-2013, 10:09 AM   #6
Rafters
No one needs to know exacty what steet you live on, looking for at least the state so the guys can figure things like snow loads, venting, amount of insulation needed.
Unless you plan on using foam for insulation or going over the roof on the outside with SIP panels you have to also allow room for foam baffles from the soffits to the ridge for air flow.
Got some pictures of the attic area?
If you look at the top right hand side of the page where it says Welcome and tap that you can edit your location.
Old 02-16-2013, 10:10 AM   #7
Rafters
It calls for r30 but that's 9 1/2 inch insulation which won't fit in 2 by 6. N also the slanted recessed light cans r about 7 inches deep that I want to use.
Old 02-16-2013, 10:19 AM   #8
Rafters
There are factors to consider when changing from a flat ceiling with attic space above to a vaulted ceiling. The existing ceiling joists assist to keep the exterior walls from spreading. Your design needs to take this into consideration in addition to adding adequate insulation, and ventilation. If you sister the rafters you will want to consider a thermal break between them. You may also want to consider framing in false rafters, basically a set of rafters that sit on the top wall plates as your current rafters do but go up to a new ridge that is beneath the existing ridge. The advantage is less movement on your new rafters and drywall when snow and wind loads are imposed on the roof. In your area a building permit is required for structural work, you may want to go by the Building Dept. and talk it over with a plans examiner or an Inspector. If you can post some photos and dimensions you will likely receive some specific suggestions.
TheCamper is offline   Reply With Quote
The Following User Says Thank You to TheCamper For This Useful Post:
joecaption (02-16-2013)
Old 02-16-2013, 11:35 AM   #9
Rafters
Good idea about the new ridge. I def will sit them on the wall plate at bottom as if installing new rafters n by building new ridge it will still give me vaulted look but also plenty of room for insulation n room for my lights
Old 02-18-2013, 11:08 AM   #10
AHH, SPANS!!!
Rafters
are u taking out ceiling joists ( flat ceiling) and opening the room up to a vaulted ceiling or do you already have a vaulted ceiling that needs upgraded??
hand drive is online now   Reply With Quote
Old 02-26-2013, 06:21 PM   #11
Rafters
Yes I want to make dining room match the kitchen. Wich is already a vaulted
Old 02-26-2013, 10:01 PM   #12
AHH, SPANS!!!
Rafters
Thecamper gave the answer. if its a standard A frame roof the joists most likely hold the roof up by keeping the exterior walls from pushing outward unless you have a shed type roof above the ceiling joists.
what details are up in the attic above the room you want to alter?
edit to add... have you already taken the flat ceiling joists out?
Old 02-27-2013, 10:59 AM   #13
Rafters
My kitchen was vaulted when I bought house now I wanted to knock wall down between kit n dining room n vault the dining room also to match kit. The rafters in attic sit on outside wall n the joist r still up n also sit on wall. U saying if I remove ceiling joist that my wall will expand out if so then y hasn't that happened to kitchen wall I'm trying to put pics up but I can't figure how to do it from the DIY phone app. Maybe I need to b on computer to show pics?
Old 02-27-2013, 10:59 AM   #14
Rafters
I don't know what a shed type roof is I have a one story ranch
Old 02-27-2013, 11:48 AM   #15
"You can do anything"-Mom
brockmiera's Avatar
Rafters
A shed roof is pitched in one direction only as opposed to a gable roof which is pitched in two directions.
brockmiera is offline   Reply With Quote
Building a pergola having issues with "bowing" in rafters. chriscarney Building & Construction 3 06-02-2012 05:53 PM
Furring out existing 2x6 rafters kirylm Building & Construction 27 02-13-2012 11:10 PM
Help attaching 2x12 rafters... bettyb Roofing 7 02-05-2012 04:57 PM
Insulating 2x4 attic ceiling rafters help needed tseverson Insulation 2 11-01-2011 08:57 PM
checking the rafters joefromcal Carpentry 3 10-01-2010 09:12 AM
