Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-16-2011, 07:55 AM   #1
Indentured Servant
Rafter alternatives
I am putting in a shed dormer. Current rafters are 2x6, span is 14 feet. Going from a 12/12 to a 6/12 pitch. I have no ridge now, the rafters are angle cut and meet each other at the peak. I am thinking about ordering I joists instead of dimensional lumber. What I am not sure of is if I can use an I joist without supporting it at the peak. If I install a ridge board where the dormer is going, can I use joist hangers to hang the I joists?
jackpine is offline   Reply With Quote
Old 08-16-2011, 10:56 AM   #2
Moderator
Rafter alternatives
You will need ceiling joists unless the ridge is structural; http://cmfac.groups.et.byu.net/tharm...ng%20guide.pdf
Gary
Clothes taking longer to dry?
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 11:26 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 08:55 PM
Rotted Lookout Beam Supporting Barge Rafter rwbil Building & Construction 1 08-15-2010 12:40 PM
Rafter Ties on Vaulted Ceiling timsgills Building & Construction 2 01-07-2010 04:02 PM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 07:03 PM
