Racking My Brain Over Wainscoting Layout - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-02-2014, 09:36 AM   #1
Rewards Points: 40
Racking my brain over wainscoting layout
I am doing a board and batten (actually closer to a flat panel style) wainscoting project in one of the kid's rooms. Issue I am running into is that it's a corner room and two of the walls have windows. The windows are not centered on those walls. For example, one wall is 133 inches and the window sits about 33 inches from the one corner and 64 inches from the other corner.
I've seen pictures where some people just space the wall out as if the window isn't there and if a stile falls off center below the window, so be it. I've seen others were they've tried to center the wainscoting under the window and then space out from there. I was thinking maybe try to make smaller panels on the edges of the wall and then more regular sized panels in the middle to try to get some sort of centering to the windows.
Any suggestions?
TyWebb is offline   Reply With Quote
Old 07-02-2014, 08:22 PM   #2
DIY staff
Rewards Points: 7,174
Do the layout with blue tape---move it around as needed--If you don't,you could end up with a stile offset of the window--could look clumsy--
TyWebb (07-03-2014)
Old 07-02-2014, 08:49 PM   #3
Rewards Points: 14,306
Even simple graft paper doing a lay out is cheaper then messing up some wood.
A picture is always nice when asking for suggestions.
We can not see what your seeing.
TyWebb (07-03-2014)
Old 07-02-2014, 11:13 PM   #4
Pro
Rewards Points: 91
Do a layout to avoid stupid things like 1/2"-wide strips. Not once will anyone ever notice the symmetry, or balance, or centering, or the other higher-order design decisions. Not once. Ever.
Robert Cram
Robert Cram Construction
CarpenterSFO is offline   Reply With Quote
The Following User Says Thank You to CarpenterSFO For This Useful Post:
TyWebb (07-03-2014)
Old 07-03-2014, 08:54 AM   #5
Rewards Points: 40
Not sure if this will come through but here's a rough sketch of one of the walls with the off center window. The bottom rail will be a 1x8, the top rail likely a 1x4 or even 1x5 with a chair rail. Stiles will be 1x4s. Trying to keep the panel sizes anywhere from 14 to say 16 inches wide if possible just to try to keep in line with the golden rectangle theory. Trying to keep the wainscoting height around the 36-40 inch height range (can be flexible with this given how the panel layout looks).
The second wall is only 127' (compared to 133') and the distance from the one corner to the window trim is only 23', if that makes sense. Electrical outlets aren't a huge concern as there are 3 total on the two walls and I can easily move them a few inches here or there (have done this before).
Old 07-03-2014, 10:15 AM   #6
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
Personally, if I had to choose, I'd choose having them evenly spaces over having one centered under the window. Those two big spaces would drive me crazy; it would never look right to me.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
The Following User Says Thank You to mnp13 For This Useful Post:
CarpenterSFO (07-03-2014)
Old 07-03-2014, 10:54 AM   #7
Rewards Points: 40
FWIW, that picture isn't to scale. I should have noted that. I get what you are saying and neither panel immediately to the right or the left of the window would be that large! Was just trying to show the placement of the windows on the wall.
My bad. I should have clarified or drawn a better rendition. I am working on some at lunch and maybe I will repost. Thanks.
The Following User Says Thank You to TyWebb For This Useful Post:
oh'mike (07-03-2014)
Old 07-03-2014, 12:46 PM   #8
mnp13's Avatar
Rewards Points: 512
Truthfully, I would disagree with this. It's something I notice immediately. Once you get furniture in there, it breaks up the lines so things are covered so it's less noticeable. However, with nothing in front of the wall, it would be very obvious.
We have lived in our home for seven years, the previous owner did some ridiculous "improvements" that threw off the symmetry of the interior. It bothers me every time I walk down the hall. You'd think I'd be used to it by now!
Michelle
Old 07-04-2014, 07:42 PM   #9
recently retired
Rewards Points: 280
With the window where it is I don't see a good solution to keep your panels roughly the same size. With only the one wall to view from the drawing, I might consider doing a shadow box under the window. This would make space on the left is roughly 2x the space on the right. The panels would be close to the same size, 11" and 11 1/2" assuming a 3 1/2" stile.
Keith Mathewson is offline   Reply With Quote
Old 07-07-2014, 07:41 AM   #10
Rewards Points: 79
What about having two panel sizes, say a 24 inch wide panel and a 36 inch wide panel. Then alternate them to come up with a pattern that makes sense and will line up with the window in a way that will make sense. 24 and 36 won't be the right sizes but you get the idea.
eclark is offline   Reply With Quote
Picture Frame Wainscoting Layout help blobula Interior Decorating 3 11-14-2012 11:53 PM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
need new Living room layout, very confused fox_forma Interior Decorating 14 03-17-2010 08:26 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
A new definition to being High-wired: Shark Off Topic 1 03-27-2008 05:50 PM
