Rack design, is this good?
This is my first time to design or build something so could you tell me if I'm way off?
This is the start of a server rack I will be building. Most of it is done with 2x4's and the 2x6's are marked with some lines. I'm not done the portion that will actually hold the servers yet as I'm not yet sure how it will work, think it will just be adjustable plywood shelves held by 2x4's or even 2x2's on each side.
I will also be adding more X bracing on the sides, and there will be plywood on top to direct to hot air towards the back top, where I will have some ducting. The sides will probably also be plywood, but think I'll add slide locks like you see in bathroom stalls to make them removable.
The front can't have any X bracing as I need to be able to have full open access so I'm hoping the two 2x6's framing and the small X in the back will add enough strength. I will be using wood screws to put it all together.
Also for the back X, what is the best way to do it? I have two 2x4's that are going right through each other, defying the laws of physics, should I just cut a slot half way on both then insert and screw, or is there a better way?
