I'm no pro on stairs, but I've just build a new set for my porch, and am about to build a much bigger set in my barn.
I know enough to know that if you want a good looking "finished" staircase, you're looking at at least a few thousand dollars. It all depends on how fancy you want to go with materials, the design of the stairway, how long and wide it is, etc...
By "basic install," I assume that means a 36" or 42" wide, straight run up to one floor. Again, anything more than a basic 2X construction staircase will easily be a few thousand dollars. For something "nice," it could easily reach 5K or more.
Stairs are very labor intensive, and material adds of quickly, especially hard wood treads and the balustrade.
You can get a cheaper set made that still look nice, using Fir treads and skirt boards out of 1X. Still, this is a lot of work for something that looks so simple.
I'm sure the contractor would quote the job based on total rise and width (material), and labor estimate. He'll also probably be marking up the material.
Even if you were to do the stairs entirely yourself, I'd bet the material would be pushing $1,000 in the end of the day.
Good luck.
B
