Quicker To Screw Down By Using A Hammer First. - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 09:06 PM   #1
Quicker to screw down by using a hammer first.
Is this a true statement? "Is it a quicker use technique to first hammer a screw down a bit before taking it all the way down with the screwdriver?
MarineCorpsman is offline   Reply With Quote
Old 09-06-2011, 09:15 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Wish I could say I have never done that...but...
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Tom Struble (09-07-2011)
Old 09-06-2011, 10:40 PM   #3
Rewards Points: 150
I catch my guys doing it- they're fired. It's far too easy to set the screw too deep and you have now destroyed the cell structure of the wood where the screw is supposed to be holding. Maybe I expect professional results from my guys but starting a screw with a cordless is just too easy to stoop to using a hammer.
TrapperL is offline   Reply With Quote
Old 09-06-2011, 10:59 PM   #4
remodeling pro
The only time the two should ever meet in my opinion is to set up a bunch of screws for the guy with the driver. If screwing down a subfloor, we will have a helper "spot" the screws and give them a light tap to hold them vertical, then the guy with the driver follows.
troubleseeker is offline   Reply With Quote
Old 09-07-2011, 11:30 PM   #5
Rewards Points: 1,088
I guess the real question is when to predrill a hole before driving a screw...otherwise, you could split the wood.
handy man88 is offline   Reply With Quote
Old 09-07-2011, 11:33 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I do it all the time when installing cement board.
XXX
Sledge hammer with fiberglass handle... How indestructible are they? xusword Safety 3 04-14-2011 11:13 PM
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 02:56 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 03:17 PM
Hammer a screw? martinlw2000 Carpentry 14 08-30-2009 05:43 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 11:47 PM
