Quick Way To Make A Spline? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 04:52 AM   #1
Rewards Points: 452
Quick way to make a spline?
This guy uses splines to join the rails and stiles.
Is there a shortcut to making the splines, or do you just shave it by trial and error?
pman6 is offline   Reply With Quote
Old 05-02-2013, 12:14 PM   #2
Old School
Willie T's Avatar
Just buy a biscuit cutter (joiner) and a big jar of ready made biscuits.
Willie T
Old 05-02-2013, 01:14 PM   #3
joed's Avatar
Rewards Points: 11,534
To make the spline I would just some stock on the table saw.
Old 05-02-2013, 02:06 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
I agree with the video in that you can make all of the cuts on a table saw. If you make the spines the same thickness as the panel, you can make all of the cuts using the same saw set up. They shouldn't need to be shaved. They should be cut to size. The problem with biscuits for this style door is that the plow cut to accept the panel runs to the end of the stock. The plow would be exposed on the top and bottom of the stiles.
Old 05-02-2013, 04:22 PM   #5
Old School
Willie T's Avatar
Only because this guy ran them all the way through....
Willie T
Old 05-03-2013, 07:25 AM   #6
Yes, but even if he'd start and stop the plow short of the ends of the stile, he'd eat up the stock where he'd need to make the biscuit cut. If I were going to biscuit join the stiles and rails, I would do it first, then rout a rabbet to accept the panel and install a stop to keep the panel in place, much like you'd do to install glass. If there is some other way to biscuit join this door frame and trap the panel in it, I would really be interested in it.
Old 05-03-2013, 11:32 AM   #7
Old School
Willie T's Avatar
Nope. I'm also a router person, myself.
Willie T
How do you make a shower base for a oversized shower nateyro Kitchen & Bath Remodeling 4 01-17-2012 10:39 PM
Quick Step perspective flooring dawnparkin545 Flooring 1 06-25-2011 12:51 PM
Best way to make 45 degree mitre jig BobS0327 Carpentry 7 09-22-2010 12:53 AM
Help us make a remodel decision for selling home pleas 3detailer Kitchen & Bath Remodeling 11 04-27-2010 12:36 PM
10x16 eave vent intake - buy or make Rald Roofing/Siding 2 01-29-2010 06:46 PM
