Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-11-2009, 08:44 PM   #46
Well I fixed the "issue" per the pics above with the girder. I used 2 2X10's. You surely can see the girder, but once the wood dries out I will paint it the same color as the posts. I am confident this will take care of the "issue" I was concerned with. Here are the pics.
stearns86 is offline   Reply With Quote
Old 10-12-2009, 01:24 AM   #47
How many bolts did you put through the new beam per 4x4 post ?
I noticed that you put 4 in the original one, has this now significantly effected the strength of those 4x4's, also when the pressure treated posts dry out will this split and fail where the bolts are side by side ??
I am not trying to rain on your parade just worried that if they do fail it could cause injury to you and your young family and I would hate for that to happen.
Tonyeo is offline   Reply With Quote
Old 10-12-2009, 01:34 AM   #48
2. 1 top and 1 bottom. It will be fine. When I did this, I had someone come over that had a clue. If he would have been over when I was putting it together I wouldn't have had to do this.
Old 10-12-2009, 09:24 AM   #49
Extreme DIY Homeowner
Scuba_Dave's Avatar
Looks like any possible sag problem is gone
I think the white will look nice once its all painted
Are you using paint or stain?
I keep saying I'll use stain...but trying to use paint I have left
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 10-12-2009, 10:30 AM   #50
I am using paint. I painted those posts white. Since its pressure treated lumber you have to let it dry out and then you need to use primer, and then paint. Behr makes this new primer plus paint that I used. Once it gets dryed out, I will paint it. The reason I painted it white was because that is the color of the vinyl railing. The deck is brown. I like how the colors offset each other and color matching that composite decking would be a nightmare also.
Old 10-13-2009, 12:17 AM   #51
Thanks again for all the help.
More On This Topic
The beams for a patio overhead are one of the essential framing elements of a secure patio installation. Installing the patio overhead beams sounds a lot more difficult than it actually is. It simply requires cutting the boards correctly and attaching... Read More »
A deck can beautify any home and increase the home's value. Like a house, a deck that isn't on a solid foundation is a dangerous thing. Be sure to build a solid deck by correctly installing the deck girders. This can be done in the following manner. Read More »
Now we are here to establish where exactly we are going to put our 4x4 posts. Make sure that you take the measurement from the center of your first post to the center of your second post. Using your plumb line, making sure that everything is in a... Read More »
This is my pressure treated 2x4 used for the framing of your picket fence. Now on this picket fence the frame, the bottom, and the top are pressure treated 2x4's. Now since this is a 24 foot long fence we will need 6 - 8 foot 2x4's. Now when you measure... Read More »
Now we are going to show you how you can attach a new picket fence to a pre-existing picket fence. Now what we have done here is we have taken this pressure treated 2x4 and we have simply nailed it to a pre-existing 2x4 foot pressure treated frame. Now... Read More »
Staining problems on Cedar deck pomi Painting 6 09-24-2009 04:23 PM
Patio Around an Existing Deck tonyg Landscaping & Lawn Care 1 09-10-2009 08:57 PM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 09:03 PM
Ground level deck questions 4just1don Carpentry 7 06-30-2008 09:57 PM
Sagging concrete pool deck Immolate General Discussion 1 06-11-2008 11:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
