Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-07-2009, 10:41 AM   #31
General Contractor
First let me say your apology is accepted and the following is not meant to upset or offend you. Building to less then code is, as you now know, building below the minimums required. If you where in school this would mean your GPA would be 69% or less. I would not have my family or children on a structure that is built only to the bare minimum or below, I also would not expose my clients to such. Coincidentally I am very "anal" about projects I take on and have seen all through to completion including the roof.
I can also tell you that true professional carpenters and contractors are well versed in fire blocking and its proper applications. True professionals learn and understand the bare minimum requirements and when ever feasible try to exceed these requirements. I am truly sorry that you are forced to deal with less in your professional endeavors and experiences. That said fire blocking, the current compliance status of your house, and the professionalism of others has no relevance to your deck.
If codes have become more stringent they have done so because obviously the older codes experienced enough building failures to cause concerns. This alone should open your eyes to the necessity of compliance to at least the minimum standards. I hope you reconsider your actions with regards to your deck and attitude towards building permits and codes.
You should research any and all projects you are going to take on to make sure you completely understand the processes necessary to complete them. This involves more in some cases then reviewing just the building codes. If you do not understand the building codes a call to the building inspector can usually clarify things for you. Even on the professional level projects, project specs, building applications, techniques, codes, and standards should be reviewed through out the bidding and construction process.
The contractors and professionals who post here do so to assist the posters on this site with the knowledge they have obtained while doing this for a living. They do not post to make fun of, insult, ridicule, or any other malicious acts towards the posters here. There is plenty of that available at "the other site". Please remember that when reading future replies from both the pros and experienced diyers on this forum.
ARI001 is offline   Reply With Quote
Old 10-07-2009, 06:08 PM   #32
I don't have issues with building codes and permits. Where I live there is alot of scandalous activity that goes on with all this. This isn't always the case. As I mentioned if I were to have done it all over again, I would have followed a set of building codes. I relied on someone that I was confident he knew what he was doing. I am still confident in that. BUT, just because he knows what he is doing doesn't mean that what is built is going to abide by a local building code. That is the mistake I made. I won't do that again. When I finished my basement, I followed the local building codes. I printed them out and did everything according to that. I had my reasons for not getting a permit. It wasn't money and it wasn't because I was hiding anything.
I don't know where you live, but the fireproofing is rarely done correctly where I live. There are certain municipalities that are cracking down on this. All my customers THINK they are applying this stuff correctly. They think that until they get to one of these municipalties that crack down on the proper installation and they end up having to rip all the firestop out and start over. Firestopping is more that caulking a penetration with fire caulk and walking away. Most people I deal with think of it that way. Slowly but surely though that tide is turning. Hospitals are where its done correctly and that is finally filtering out. Don't forget my example with epoxy anchors. That application is far worse that the firestop. Also there are new IBC codes coming out and contractors that are finding ways to cut corners. You'd be shocked.
In the end, I can't afford to rip this whole thing apart. To do some of the stuff suggested on here calls for that, and I won't do it. I am just trying to sure this up the simpliest way I can, and people have offered that to me. I can assure you the next time I build a deck(I may never have to again), that I will take this thread in stride and go this direction to prevent this from happening again.
stearns86 is offline   Reply With Quote
Old 10-07-2009, 11:39 PM   #33
Hey,Stearns, Please come back and post the"fix".when it's done.
To often we never get to see the end of the story.--MIKE
Old 10-08-2009, 11:21 AM   #34
Old School
Willie T's Avatar
With all the "I don't see it"..... "I think I've got it".......and "Not sure it will work", I thought I'd post a drawing of what I believe Al is talking about.
So everyone can be on the same page.
questions-deck-i-just-built-deck-girder.jpg   questions-deck-i-just-built-deck-girder-2.jpg
Willie T
Old 10-08-2009, 08:15 PM   #35
WillyT that should help him a lot!
Old 10-08-2009, 08:32 PM   #36
Extreme DIY Homeowner
Scuba_Dave's Avatar
Originally Posted by stearns86 View Post
Ok, so back on topic. I took some pictures for you guys that are actually trying to help me. I still don't see how I can do what you want Deckman. The pictures will give you an idea why I can't picture what you are saying.
Willie if you look at these pics you will see that the outside beam - farthest from the house is not under the joists
The joists are connected TO the "beam" (rim joist) & the rim joist is bolted to the 4x4 posts
The middle support beam is under the joists
Note the outside rim joist
Then on the outside of the rim joist is a fascia board
That seems to be the problem here...I think - based on 1st pics he posted of finished deck
Unless you are saying to add BOTH red boards as a beam?
But then they will stick out - below the fascia board
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Old 10-08-2009, 09:30 PM   #37
Bingo, Willie.
It won't quite be code compliant, but didn't figure he was into making it such. To pass code you'd have to add solid blocks (2x4's) under beam, nailed into post. No more than 6' span between support post, so he'd still have to add more posts/footings. The spans on the joist are fine. Probably a few nit picky other things, but should be good to go after a little fine tuning this weeking by OP'er.
deckman22 is offline   Reply With Quote
Old 10-08-2009, 11:10 PM   #38
You are correct. If you look underneath on my pic, the fascia goes about another 3-4" down below my outside board. If I were to do what he is saying, it would have raw wood showing which defeats the purpose of the fascia. Let me ask this though. If I were to go this direction, what if I cut out slots on the boards I am adding(girders) and then slide them underneath and bolt them so that they fit the full length of the fascia? If add two more 2x8's, cut the slots out to fit, and then bolt them to the post, do you guys think this will cure my issue of sagging in the future? Cutting those slots won't be easy, but I have the right tools to do it. We have had a ton of rain here, so if you all don't think that will work, I will just add more posts to that outside board in then it will cut the distance between posts from 10' to 5'.
Originally Posted by deckman22 View Post
Bingo, Willie.
Thanks. These last 10 or so posts are what I was coming here for. I can assure you if I ever did this again, I will be code complaint so I don't have to go through this again.
Old 10-08-2009, 11:59 PM   #39
If you cut slots in the 2x8's you defeat the purpose, the added support for the rim joist.
I don't see the big deal about a little wood showing, it'll be under the deck. A lot of decks are built with a support beam at the exterior post so it won't look out of place.
Old 10-09-2009, 12:21 AM   #40
Old School
Willie T's Avatar
Correct. BOTH red boards are the "girder".
Willie T
Old 10-09-2009, 12:23 AM   #41
Deckman is right. No one will think a thing about a girder behind the posts.
Old 10-09-2009, 12:45 AM   #42
I am anal as can be about that though. If yo noticed I painted those posts for the same reason. Honestly no one would see it but me, but I am just picky. I will probably just put post in and be done with it. I figured putting those slots in wouldn't work, but I thought I'd ask.
Old 10-09-2009, 01:03 AM   #43
You know what, you guys might be right. I am going to do this on Sunday and will take a look and see what I think. Should I do one board or 2?
Old 10-09-2009, 01:11 AM   #44
Old School
Willie T's Avatar
2 And flat black would hide a lot back in there.
Willie T
Old 10-09-2009, 02:28 AM   #45
From your first post: " The spacing is roughly 7 1/2 feet between posts." -------- This is what I based the loads on.
Now you say: "We have had a ton of rain here, so if you all don't think that will work, I will just add more posts to that outside board in then it will cut the distance between posts from 10' to 5'." ------ Based on 10' to post = 2500# total load = a 2x12 3-2x8's would only give you 1680# or 820# short, will not work. Shorten span to 5' = your 2x8 is still over-spanned by 1'.
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
More On This Topic
Verbal contracts seldom hold up in court, so if you're planning a home renovation, even if it's with a contractor who is personally known to you, you should always make a written agreement. You'll want to specify, in writing, the exact work to be... Read More »
Fencing Codes
Fencing Codes by Expert Village
On behalf of Expert Village, I'm Terry, and I'm here to tell you today about building a wrought iron fence. Before you start any project, it's always helpful to know what your codes are for the city or the county, whatever the governing body is, what... Read More »
Adding a conservatory to an existing home has become a hot commodity amongst home owners. Not only is it a way to increase living space, adding a conservatory can boost the overall value of a home. Before you get started on your project, however, read... Read More »
Many outdoor fireplaces are fancier than indoor ones. Some expensive fireplaces stand over eight feet tall and include MP3 docks. Less fancy ones are just a metal bowl with legs. Almost anyone can afford an outdoor fireplace because there are many styles... Read More »
If you are looking for a swimming pool that will last for years, gunite is the way to go. But buying a gunite swimming pool is different than purchasing other home additions. Follow these steps. Read More »
Staining problems on Cedar deck pomi Painting 6 09-24-2009 04:23 PM
Patio Around an Existing Deck tonyg Landscaping & Lawn Care 1 09-10-2009 08:57 PM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 09:03 PM
Ground level deck questions 4just1don Carpentry 7 06-30-2008 09:57 PM
Sagging concrete pool deck Immolate General Discussion 1 06-11-2008 11:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
