Questions About Deck Work From Contractor (pics) - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 12:36 PM   #16
Rewards Points: 12,802
That's correct.
I set all mine at 3-3/4 that way if the wood wants to curve before it's inspected it should still pass if they want to get fussy.
Old 07-26-2013, 04:29 PM   #17
journeyman carpenter
woodworkbykirk's Avatar
here handrails only have to be at 42" off the deck platform if the deck is higher than 6' off the ground.. as for spindel spacing code calls for 5" o.c as long as the gap is no more than 4" between .. the actual o.c spacing will vary depending on the thickness of the spindle material. as for gap under the bottom rail there is no code about that here
woodworkbykirk is offline   Reply With Quote
Old 07-27-2013, 08:59 AM   #18
AHH, SPANS!!!
Rewards Points: 1,166
the bottom rail holding the picketts going down the steps would certainly not pass. it needs to be closer down to the front edges of the front stair treads about 1/2" to 1" off front tread will work with the 5" round diameter requirement.
hand drive is offline   Reply With Quote
Old 07-29-2013, 11:17 AM   #19
Mold!! Let's kill it!
Rewards Points: 2,012
Originally Posted by awsd401 View Post
Thanks for all the replies. We told the contractor to hold off on staining as we are trying to figure out what to do.
We are in San Diego. I went on the city website http://www.sandiego.gov/development-...etin/ib211.pdf and found this under residential decks:
"Guards shall provide for a complete protective barrier not less than 42 high completely around the deck if the deck is higher than 30 above grade. Guards shall not have openings which allow passage of a sphere of more than 4 in diameter."
I'm guessing this would apply to the lower rail not only on the stairs but around the whole deck?
The 4" sphere would apply to the rail around the deck, but on stairs the measurement from the rail to the tread is usually 6".
Old 08-11-2013, 10:50 PM   #20
First of all I've never seen anyone use wood filler.Second the cracks are because they should have drilled and countered sunk the holes.Third the straight pieces won't match because of the 45% angle maybe if he planed the 45% piece a little it would match better.
ron tredo is offline   Reply With Quote
Tags
cedar , contractor , deck
Miscellaneous deck questions NewHomeDIYGuy Building & Construction 38 09-17-2012 03:41 PM
Deck Staining - Newcomer questions rnb67 Painting 6 07-22-2012 09:00 PM
Freestanding 16 x 14 deck questions ctandc Building & Construction 11 09-27-2011 01:46 PM
Building deck on side of Gambrel style roof - questions sheslostcontrol Building & Construction 14 05-11-2011 12:15 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
