Question Re: Fiber-cement Soffit Material - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-12-2006, 11:38 AM   #1
Question re: fiber-cement soffit material
Hi, I'm a homeowner currently selecting siding product(s) for my house that needs residing. I've chosen CertainTeed WeatherBoard™ lap siding and foam trim. My question is about what material to chose for soffits.
My contractor "suggested" going with Smart Soffit™ which is wood composite(?) rather than a fiber cement soffit. His reason is that the weight of cement board used on the soffits will cause the the soffits to sag either by having the nail head pull through the board or even pull the nails out of the rafter tails.
Of all the reading I've done on the internet about fiber cement products, I've yet to read about such a problem with using it for soffits. He claims he's learned through experience. I'm troubled with the concept of spending $8-9,000.00 for fiber cement siding and foam trim (all highly moisture resistent), only to finish with soffit material (wood composite) that's susceptible to moisture.
Has anyone experienced with these material ever heard of such a thing? Any help would be appreciated.
Thanks,
Mike
MichaelinOmaha is offline   Reply With Quote
Old 10-12-2006, 11:50 AM   #2
Center to center distance of roof rafter or nailing structure?
redline is offline   Reply With Quote
Old 10-12-2006, 12:15 PM   #3
Thanks,
Roof rafters are 2x6 24" O.C. 2x6 subfascia.
Mike
Old 10-12-2006, 08:20 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks,
Mike
This depends on what kind of soffit venting you will use.
My recomendation and the way we do it is the most common way on new construction homes.
1x3 (1x 2 1/2") Pre-primed Lumber (Or KOMA trim - see below)
White Aluminum 1" soffit vent strip
1x3 (1x 2 1/2") Pre-primed Lumber (Or KOMA trim)
To fit your desire for a weather resistant material: Look into AZEK Board...or..... KOMA trim products. These are PVC based and look just like real wood. They come in a variety of sizes (1 x 3" up to 1 x 12")They come white, if you leave them that way, they are maintenance free...or you can also paint them. Great looking material.
- Build Well -
Old 10-12-2006, 08:30 PM   #5
Thank-you.
What a great solution! I will check the respective websites.
Sincerely,
Michael
Siding Options Vinyl vs. Fiber Cement obrien11j Building & Construction 35 09-26-2011 06:08 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 05-01-2007 12:14 AM
Soffit installation question milano Roofing/Siding 4 02-04-2006 11:13 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
