Question On Raised Panel Cabinet Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-13-2008, 08:53 AM   #1
Rewards Points: 216
Question on Raised Panel Cabinet Door
I have oak kitchen cabinets with raised panel doors. We would like to remove the panels from 1 pair of doors and insert frosted glass. A bit of an upgrade after 15 years. I still have 1 extra pair of doors (from dishwasher filler cabinet).
Is there a simple way to remove the panels?
orange is offline   Reply With Quote
Old 03-13-2008, 11:05 AM   #2
Custom Cabinet Maker
Sorta :}, you have to have a rabbitt to hold glass anyway so you need a router, then make a jig, and you CUT the back of the frame, pull panel out, then finish rabbitt to whatever dimension you want , put glass in and retainers on back or set glass into silicone.
skymaster is offline   Reply With Quote
Old 03-13-2008, 06:28 PM   #3
Rewards Points: 216
Thanks Skymaster
I solved it. The cut out for the raised panel is offset such that a "rabbitt" exists. I took my skill saw and made plunge cuts into the panel away from the geometry that formed the rabbitt. I finished the cuts with a handsaw; then with a wood chisel made a few gaps in the remaining piece of the panel (part held in stile and rail); then pulled the pieces out by hand.
It did the job.
Have been to a glass shop and ordered glass.
Glass Fuse Panel box question? pouncerw Electrical 4 10-05-2009 09:01 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
Fixing a door with broken out panel justdon Carpentry 2 09-09-2007 07:35 AM
Question on installing cabinet door hardware Boatnuts Remodeling 4 03-19-2007 09:46 AM
