Question On Basement Ceiling Framing - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 10:45 AM   #1
Question on basement ceiling framing
In the process of finishing my basement. I need to frame around the duct work running the length of the basement but need to save as much headroom as possible. My question is will 2x4's laid flat support drywall without sagging? (about a 4' span)
GravelGuy is offline   Reply With Quote
Old 02-14-2013, 10:56 AM   #2
"You can do anything"-Mom
brockmiera's Avatar
Your bulkhead is going to span 4' or the drywall is going to span 4'?
brockmiera is offline   Reply With Quote
Old 02-14-2013, 10:56 AM   #3
brockmiera's Avatar
Oh a picture would help too. Then I could draw all over it in Paint and post it back up.
Old 02-14-2013, 11:03 AM   #4
Can't supply a picture right now. The widht across the ducts is about 4'. I can support from joists on both sides so the 2x4 will span about 4'. I want to lay the 2x4 fllat (3.5" side down), but didn't know if it would sag with the weight of the drywall?
Old 02-14-2013, 11:48 AM   #5
brockmiera's Avatar
I dont think you will have any problems with that. I'd wait on a few others to chime in. Make sure you frame 16" O.C. the length of the bulkhead too.
The Following User Says Thank You to brockmiera For This Useful Post:
GravelGuy (02-14-2013)
Old 02-14-2013, 12:17 PM   #6
Newbie Bill
Rewards Points: 522
I'm curious as to what the experts suggest as well.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 02-14-2013, 02:28 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,348
if its simply a bulkhead just use 1 5/8 steel stud and track.. the only weight it has to hold is the drywall itself
woodworkbykirk is offline   Reply With Quote
Old 02-14-2013, 05:02 PM   #8
firehawkmph's Avatar
Rewards Points: 1,922
What Kirk said would work, your 2 x 4 on the flat would work. I usually use 1 x 6 t & g knotty pine to span the ducts and wrap the vertical sides. You still have to build a wall on either side, but you only have to have it drop about a 1/2" below the low point of the ductwork. Its a nice look and breaks up the drywall look.
firehawkmph is offline   Reply With Quote
Old 02-14-2013, 05:10 PM   #9
Newbie Bill
Rewards Points: 522
Nice idea. I like the fact you don't lose much headroom with this method.
Bill
Old 02-14-2013, 05:25 PM   #10
MikeKy55's Avatar
Rewards Points: 254
I had a supply and return duct running down the middle of mine. I am far from a professional, but I built ladder bulkheads on each side, laid the 2X4 flat running across and then stood a 2X4 vertical down the center, screwed it to each crossmember and every 4 feet ran a short piece of 2X4 up to the floor joist above. This gave me about 2 more inches of headroom. Once it was all fastened, I grabbed the crossmembers and hung my body weight from them (about 190 lbs). They didn't move. This was probably over kill, but I'm known for that. I used 5/8th drywall on the ceilings and was a little worried it would sag.
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
The Following User Says Thank You to MikeKy55 For This Useful Post:
GravelGuy (02-18-2013)
leveling basement ceiling driving me nuts BlueBSH Building & Construction 8 02-07-2013 02:46 PM
basement framing / insulation question in storage portion of finished basement. cobra5laddict Insulation 5 03-22-2012 09:59 PM
Basement Remodel - HVAC Code Question buckybadger HVAC 2 08-16-2011 05:34 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
Question about Insulation of unheated basement ceiling dpdolstad Building & Construction 9 03-10-2009 12:49 PM
