Question About Wood Screws Breaking - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-06-2012, 09:52 PM   #1
Rewards Points: 682
Question about Wood screws breaking
When driving in wood screws by hand I've occasionally had screws break off at the head or middle when things got tight. But I've never broken a wood screw when driving it in with a electric drill. Why is this? It doesn't seem logical, since the drill applies more velocity and force you would think it would be more likely to break wood screws.
darsunt is offline   Reply With Quote
Old 01-06-2012, 10:08 PM   #2
Ironlight's Avatar
The drill driver applies continuous torque and keeps the screw turning against the friction of the wood. On the other hand, whenever you drive a screw by hand you need with each twist to start it turning again and overcome the initial contact friction of the screw against the wood. You probably torque it pretty hard to get it turning and that in turn fatigues the metal until it fails.
Edit:
I always try and drill pilot holes slightly smaller than the screw's minor diameter (the diameter of the shaft minus the depth of the screw threads). Not only do screws drive easier but you maintain the integrity of the wood grain by not crushing it, resulting in greater holding power. You can also more precisely place the screw.
Also, consider if you're using the right screw for the job. Drywall screws, which have become defacto "all purpose" screws to a lot of people, have fairly weak torsional strength compared to wood screws.
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
Snav (01-06-2012)
Old 01-06-2012, 10:52 PM   #3
In a little over my head
Rewards Points: 706
I've noticed that, too. Try some beeswax on the screw threads.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
Snav (01-06-2012)
Old 01-06-2012, 11:01 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Very logical explanation. Well said.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
PT Wood Question Branden Building & Construction 1 08-23-2010 03:26 PM
wood fencing question march7 General DIY Discussions 6 05-09-2008 12:13 PM
Laying Wood Floors - subflooring question drewz Flooring 8 09-21-2007 09:56 AM
Wood Burner Installation Question? fisher501 HVAC 1 12-22-2005 10:29 PM
Question About Bolting Wood Together for a Loft ArcticRSXS Building & Construction 15 09-16-2005 05:42 PM
