Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-31-2010, 08:32 PM   #1
Question about replacing fascia and soffit paneling
Hey gang,
We are getting some superb weather this weekend here in western NY, gonna reach the 80's!!! so I thought this was a good time to get this project knocked off. I removed the gutters and gutter spikes tonight and hopefully will have this done by Saturday before it rains.
I am going to replace my partially rotted fascia and soffit paneling. I have a ranch house. The exisitng fascia is 1x6 painted pine and the soffit material is 1/4" plywood painted.
I plan on using pre primed 1x6 pine again and paint it. What type of fasteners would be best for the fascia boards? I have on hand alot of ring shank stainless 6d 2" nails that I use for my cedar siding, would these work?
The soffit material I plan on using BC plywood, either 1/4" again or 3/8" prime it then paint it, again should I use any specific fasteners like galvanized or stainless, or would bright common work fine for both fascia and soffits.
Any other things I sould be aware of please chiime in, this is my first fascia and soffit project
Thanks for any input
creamaster is offline   Reply With Quote
Old 03-31-2010, 09:37 PM   #2
Xtreme DIY'r
Are you installing any venting ?
Old 03-31-2010, 10:01 PM   #3
Yes, I will likely use 4" round soffit vents.
Vinyl soffit and fascia msyv Building & Construction 7 09-13-2009 11:21 PM
Help with installing aluminum soffit and fascia Boontucky Roofing 3 09-01-2009 08:47 PM
Plastic fascia and soffit panel attaching to it. 4just1don General Discussion 1 07-22-2009 10:26 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing 10 02-11-2008 08:34 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
