Question About The Need To "sticker" Wood - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-14-2010, 02:55 PM   #1
Rewards Points: 39
Question about the need to "sticker" wood
Hi all,
I just received about 6,000 LFT of cedar shiplap 1x8 siding at the house, which I've started to pre-stain. I know that wood needs to be stored/stacked with stickers for longer term concerns about warping, splitting, etc... problem is, if I try stickering every piece that I have stained thus far, I'll be spending more on stickers than I did on the siding. The siding will be outside, on pavement, and covered for a maximum of three weeks 'til it goes up. Suggestions on storage please??? could I at least sticker it every few layers or something??.....thanks in advance for any suggestions,
Sam
Sampson is offline   Reply With Quote
Old 11-14-2010, 03:00 PM   #2
Registered User
Termite's Avatar
Stickering is more a means of storage of wood that has not been dried, as it promotes air circulation. I see no need to sticker wood that has already been dried and milled. Keep it up off the ground and keep it covered from rainfall and you'll be fine. If it isn't neatly stacked for storage you can count on losing a lot of it to warping, etc.
The Following User Says Thank You to Termite For This Useful Post:
Sampson (11-14-2010)
Old 11-14-2010, 03:07 PM   #3
Rewards Points: 39
...That's definately what I was hoping to hear...I had hoped to get it stickered underneath every 12-16" to keep it off the pavement, and get it covered over as I go. Naturally, with this amount of material sitting, I'm a little uptight about maintaining the integrity of it...
Old 11-15-2010, 12:06 AM   #4
Registered User
Rewards Points: 5,520
"about maintaining the integrity of it.."------ just a few thoughts.
1. Back-prime the wood for water-proofing, and edges, or rain screen?
2. Tar paper or house wrap, which brand?
3. Foam board behind or no?
4. Location?
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Sampson (11-15-2010)
Old 11-15-2010, 06:18 PM   #5
Rewards Points: 39
Thanks for the reply/thoughts Gary, I'm in Connecticut, have stained the board ends but didn't feel the need(hopefully) to back prime it (I had hoped that by going with cedar I could avoid the rot concerns that I'd have with pine...and am using Tyvek housewrap.
Old 11-15-2010, 08:09 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
always prime all sides...always
Tom Struble is offline   Reply With Quote
Old 11-16-2010, 08:03 PM   #7
Registered User
Termite's Avatar
Agreed, you MUST ALWAYS BACKPRIME wood siding. Cedar siding too!
Old 11-16-2010, 10:08 PM   #8
Registered User
Good points from J.S. who now is with Building Science: http://www.canadianarchitect.com/iss...int%20Archives
Heating or cooling climate: http://www.hgtvpro.com/hpro/dj_const...065324,00.html
Seal the house wrap: http://docs.google.com/viewer?a=v&q=...WrZBbBZoIUXgxw
Drainable house wrap locations: http://docs.google.com/viewer?a=v&q=...RvUBSlz4b5thmA
Perm difference: http://www.typar.com/pdfs/Typar_vs_Tyvek.pdf
http://www.dickseibert.com/martin.pdf
Interesting on rain screen: http://www.greenhomebuilding.com/pdf/RainScreen.pdf
Are you using 5/4 or 2x trim at the windows, do you know to use backer rod?
Gary
Is stripping/sanding to bare wood necessary? hf12358 Painting 13 09-06-2009 09:14 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood Burner Installation Question? fisher501 HVAC 1 12-22-2005 09:29 PM
Tricky Wood Stove Question Mosca General DIY Discussions 7 12-22-2005 12:42 AM
