Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-04-2011, 09:14 PM   #1
question about finishing basement walls / framing
Half of my basement was already finished when I moved into it. I plan on finished the rest of the basement and had a question regarding framing the walls. I know the bottom plate must be pressured treated. From what I have researched, it seems most studs are nailed to the bottom (pressure treated) plate. Is there anything wrong if I had a second (non pressure treated) bottom plate to nail the studs into? I like to build each wall section and then sit it on top of the pressure treated bottom plate. Please let me know if I made this confusing and I can try to put a diagram up.
Thx in advance for any advice given.
Mark
indianboy08 is offline   Reply With Quote
Old 12-04-2011, 10:22 PM   #2
The only issue would be to use fasteners that will be compatible with the pressure treated lumber.
Ron
B. Franklin 1759
Old 12-05-2011, 12:40 AM   #3
Disabled wood vet
titanoman's Avatar
That won't hurt anything. Also, use treated blocks to hold your wall away from the concrete wall.
titanoman is offline   Reply With Quote
Old 12-05-2011, 06:23 AM   #4
Thx for the advice.
basement framing question, PT walls? brewcrew Building & Construction 2 08-27-2011 06:51 PM
Framing basement walls Dude Remodeling 1 02-03-2010 01:52 PM
Finishing basement question blaze01 Building & Construction 5 01-20-2010 09:25 AM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 07:27 PM
finishing basement question fabian Building & Construction 6 06-19-2009 12:59 PM
