-   -   question about finishing basement walls / framing (http://www.diychatroom.com/f14/question-about-finishing-basement-walls-framing-125619/)
indianboy08 12-04-2011 08:14 PM
Half of my basement was already finished when I moved into it. I plan on finished the rest of the basement and had a question regarding framing the walls. I know the bottom plate must be pressured treated. From what I have researched, it seems most studs are nailed to the bottom (pressure treated) plate. Is there anything wrong if I had a second (non pressure treated) bottom plate to nail the studs into? I like to build each wall section and then sit it on top of the pressure treated bottom plate. Please let me know if I made this confusing and I can try to put a diagram up.
Thx in advance for any advice given.
Mark
Ron6519 12-04-2011 09:22 PM
The only issue would be to use fasteners that will be compatible with the pressure treated lumber.
titanoman 12-04-2011 11:40 PM
That won't hurt anything. Also, use treated blocks to hold your wall away from the concrete wall.
indianboy08 12-05-2011 05:23 AM
Thx for the advice.
