Question About Board & Batten Houses - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-20-2009, 08:00 PM   #1
Question about board & batten houses
Curious how you maintain a board and batten house?? I'm thinking of buying a house with board and batten siding not sure what work comes with that? : )
Lilamilz is offline   Reply With Quote
Old 07-20-2009, 08:06 PM   #2
General Contractor
Same as clapboard siding. You will have to paint or stain every so many years length dependant on the finish and the quality of the material being used.
ARI001 is offline   Reply With Quote
Old 07-21-2009, 08:50 AM   #3
Registered User
Termite's Avatar
I think that maintenance of caulked horizontal joints is a lot more critical with board and batten siding. A lot of homes around here were built in the 60's-90's using masonite and they didn't make any attempt to flash the horizontal pieces or the horizontal butt seams and they're really degrading...You can definitely tell who has done the upkeep and who hasn't. If properly flashed and the caulking is maintainted (replaced every few years) there's no reason to be concerned.
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 11:50 PM
Cement Board Install Question AVTechMan Building & Construction 9 03-19-2009 03:45 PM
Hardiebacker 500 in shower enclosure question (does board facing matter?) DyerWolf General DIY Discussions 3 01-20-2009 07:58 PM
sagging roof, rotten ridge board sonoflee Roofing/Siding 6 01-29-2008 07:12 PM
