Quarter Round And Kitchen Cabinets - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-31-2008, 04:30 PM   #1
quarter round and kitchen cabinets
How do I cut quarter round thinner in certain places to go around the vertical moldings on the corners and other areas of my kitchen cabinets?
knmadary is offline   Reply With Quote
Old 11-01-2008, 05:58 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
It's easier to cut the corners (extended portion) of the cabinets, and install your quarter round. Just be very careful to make the cuts exactly the same height as the quarter round.
Use a scrap piece of Q-round to hold up to the cabinet corner, and mark.
May be easiest to use a sharp utility knife for the cutting.
- Build Well -
Old 11-01-2008, 09:29 AM   #3
ther are a few ways of doing what you want 1 you can rip something the same thickness of the verticals if you had any fillers left over 2 you could mark the cabinet and cut with a coping saw 3 you could notch the quarter round I would rip the filler hope this helps Rob
super carpenter Rob is offline   Reply With Quote
Replacing Kitchen Cabinet Toe Kicks KyleV Carpentry 1 04-02-2008 06:19 PM
Finish off Quarter Round JCHandy Flooring 5 07-01-2007 02:14 PM
Need help with Toe-Kick & 14 round. dragondesigns Flooring 1 03-27-2006 09:30 PM
