Quarter Round In Basement? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-23-2007, 08:53 PM   #1
Quarter round in basement?
We had a laminate floor installed in our basement when it was finished recently. There are noticeable gaps between th base boards and the floor. Fanfold was used as an underlayment so theres a little bounce to the flooe resulting in the gaps I guess. Anyway, the contractor said that he can't install quarter round for two reasons...
First he said he can't nail it into the floor since the floor is obviously cement under the wood. Ok, that makes sense.
Then he said that he can't glue the quarter round to the floor because it won't hold up. I'm not sure why....
If you just glue the bottom of the quarter round to the floor and not the wall, it can still expand.
He wants to use flexible caulk instead which I'm not very happy with.
Any thoughts?
Thanks in advance!
xray328 is offline   Reply With Quote
Old 07-23-2007, 09:42 PM   #2
Automotive Enthusiast
Sellncars's Avatar
Send a message via AIM to Sellncars Send a message via Yahoo to Sellncars
Any thoughts?
Thanks in advance!
Why not just use new baseboard moulding?
Sellncars is offline   Reply With Quote
Old 07-23-2007, 10:26 PM   #3
zel
Rewards Points: 150
Send a message via AIM to zel
Sounds like it was not installed by someone with any pride in what they do. I cant see how anyone would consder that a "finished" installation of flooring. If the gaps are less then half an inch, you can put on baseboards like suggested above, if the gaps are larger, baseboards first, then quarter round, and the quarter round can be nailed to or glued to the baseboards.
zel is offline   Reply With Quote
Old 07-23-2007, 11:08 PM   #4
There is baseboard moulding.
The gap is between the baseboard moulding and the floor.
Is there a reason you can't put quarter round down in this situation?
Old 07-23-2007, 11:42 PM   #5
Darylh's Avatar
Sure why not, you could glue and brad it to the flooring useing the right length of brad or you can brad it into the baseboard. Sounds to me hes just plain lazy and doesent want to spend the extra time. Do not let him caulk it, it will discolor and look terrible.
Darylh is offline   Reply With Quote
Old 07-24-2007, 07:08 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Sounds like inexperience to me....
BTW: Quarter round or "Shoe-base" is supposed to be nailed into the Baseboard, not the floor.
- Build Well -
small quarter round moulding mf915 Flooring 11 09-30-2009 01:14 AM
Installing Quarter Round shanmon Flooring 4 07-19-2007 01:59 PM
Quarter round on round outside corners biyoba Flooring 4 01-07-2007 08:39 PM
Laminate Flooring Quarter Round Cuts no3jack Flooring 1 12-11-2006 09:30 PM
Quarter round and baseboard justtired Flooring 1 09-30-2006 05:39 PM
