Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-13-2011, 08:55 AM   #1
DIY Enthusiast
PVC Interior Trim/Extension Jambs
After 45ish years of DIY experience, I just discovered this chatroom. Happy to be here.
Don't want to commit heresy but I want to attach PVC jamb extensions to new construction PVC windows (American Craftsman 3000 Series) and then apply PVC interior trim to the extensions. I've done a lot of work with exterior PVC trim but there's no need to attach exterior trim to the window unit - the exterior of the windows already have colonial-style molding fused to the window.
My primary question is - what's the best way to attach the inner edge of the PVC extension jamb to the PVC window? I know the 4 pieces of extension jamb need to be nailed to the wooden studs and/or attached to each other with screws to form an extension "box". But, isn't it necessary to somehow attach the inner edge of the extension jamb to the window?
Should I use PVC cement? Caulk? Nothing at all?
I noticed on these American Craftsman windows there is a groove around the entire inside perimeter of the window unit. Is this groove designed to receive some type of attachment to the PVC extension jamb? If so, it sure would solve the attachment and alignment challenge.
As far as the PVC trim is concerned - do folks use a PVC cement product or caulk to fuse the mitered trim pieces?
Thanks, in advance, for any advice.
DrMike is offline   Reply With Quote
Old 04-13-2011, 09:03 AM   #2
I'd just caulk it. I would not fuse the trim to the window.
I would glue the miter joints of the interior molding, though.
Ron
Old 04-13-2011, 09:06 AM   #3
DIY Enthusiast
Ron
Thanks for the recommendation. Is there a particular type of caulk you would recommend? I would want the seam to be as invisible and long-lasting as possible.
Old 04-13-2011, 09:43 AM   #4
If you're going to paint the trim, use an acrylic or latex caulk. If not use a 100% silicone caulk.
Ron
Old 04-13-2011, 09:53 AM   #5
DIY Enthusiast
Ron
Thanks again. Any idea what the groove around the inside perimeter of the vinyl window is for?
Old 04-13-2011, 10:49 AM   #6
It could be an inset for the extension jamb to go into. Andersen windows have this inset for the extension jambs they sell.
A picture would help with the identification.
Ron
Old 04-13-2011, 12:04 PM   #7
DIY Enthusiast
Ron
A picture is attached -The groove/slot is around the very edge of the window and is approximately 1/4" deep:
PVC Interior Trim/Extension Jambs-groove2.jpg
Old 04-13-2011, 12:36 PM   #8
Looks to be part of the window design to add a stiffening aspect to the vinyl.
Ron
Old 04-13-2011, 12:48 PM   #9
KemoSabe
loneframer's Avatar
Here's my go to product for PVC trim. I've used medium bodied PVC cement as well.
PVC Interior Trim/Extension Jambs-003.jpg
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 04-13-2011, 01:17 PM   #10
DIY Enthusiast
Looks like just the right product. Can you purchase it in these small tubes at retailers or do you order it directly from T. Christy Enterprises?
Old 04-13-2011, 01:55 PM   #11
KemoSabe
loneframer's Avatar
It's available at most lumber distributors in this area. Runs about 15 bucks for that tube, which goes further than you'd think. It's also available in caulk tubes for situations that require larger applications. The down side is, the product keeps running after the pressure from the push rod is released.
Christy's is aggressive and any squeeze-out should be wiped away with a rag dampened with Goof Off, or similar product. If left on the surface, it will eat into the finish.
What kind of material do people use for extension jambs? tsg234 Building & Construction 5 03-09-2011 12:02 PM
Cabin jambs zainalms2002 Building & Construction 2 10-18-2010 07:56 AM
Sandpaper for door jambs? ws450r Painting 2 08-20-2010 09:34 PM
Paint for jambs to seal the pitch in ? scarrylarry Painting 7 06-11-2010 04:48 AM
Installing Window Jambs rde476r General Discussion 9 03-27-2009 05:36 PM
