Putting A Vapor Barrier Or Tyvek Under Stone - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 02:19 PM   #1
Location: HOPEDALE MASS 01747 AND PHIPPSBURG MAINE 04562
putting a vapor barrier or tyvek under stone
hey DIY, looking for some professional opinions, i have a 8x14 deck that is about 12inchs above the ground the deck boards have been removed because of some rot that was visible, now all that is there is framing and is also showing signs of rot, i am seeing some rot under the sill, looks like a 1x4 or 1x5 that is under the sill and on top of the cinder blocks, this runs the width of the deck about 8ft, it is very much rotted in some spots, how can this be removed without getting to involved? i also had water leaking thru the foundation in this area, so i was thinking on putting down a vapor barrier and crushed stone for drainage purposes, lowes said i could use tyvek because one side is waterproof while the other side will breathe. i am in phippsburg maine for the week at my second home and would like this straightened out before i leave this weekend.
thanks so much
jeff
paint79 is offline   Reply With Quote
Old 07-24-2012, 02:38 PM   #2
Rewards Points: 502
Don't ever listen to advice from anyone who works in one of the big stores. Tyvek is not for this situation.
tony.g is offline   Reply With Quote
Old 07-24-2012, 02:54 PM   #3
ok thanks tony, what is your suggestion
thanks jeff
Old 07-24-2012, 03:19 PM   #4
Rewards Points: 502
Without seeing pics of the situation, I wouldn't know. Is the house on a slope? Is the wall poured concrete, CMU or stone? Is the wall just damp or is water actually coming through?
If it's water coming through, you obviously need some form of tanking, whether internal or external. Retro-fitted external tanking, as you suggested, may not necessarily work, as you can get leakage through the wall/floor joint. If you do consider that, something more substantial than Tyvek would be needed.
Internal tanking and drainage is usually best, though expensive. I suppose a lot depends on what you want to use the space for.
Old 07-24-2012, 03:46 PM   #5
there is a door leading out to the deck, the threshold has rot on the outside, i am assuming from water splashing up off the decking when it is raining, this area is where water can find it's way down the foundation, the deck and ground are level, no slope, some of the foundation is cinder block [newer], below is older stone wall[ 1870's], in maine all basements have some dampness, there was no flashing under threshold so this needs to be corrected,the cinderblock cavity's are seen from the outside on some spot's, this needs to be filled with concrete i would think. the crushed stone i am thinking will help with drainage, the vapor barrier was a afterthought.
thanks for your input
jeff
Old 07-24-2012, 09:18 PM   #6
Rewards Points: 53
Was your deck ledger board flashed properly? This is often done incorrectly or not at all, and can cause infiltration and rotting as you describe above.
smrf1080 is offline   Reply With Quote
The Following User Says Thank You to smrf1080 For This Useful Post:
jaydevries (07-24-2012)
Old 07-24-2012, 09:33 PM   #7
Rewards Points: 630
look at this pic for what it should look like
http://www.google.com/imgres?q=ledge...9,r:5,s:0,i:90
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 07-25-2012, 08:08 AM   #8
yes lead flashing was used on one side 14ft, but not under doorway wall 8ft, thanks for the photo, my siding is old 1800's wood, still in good shape though, the floor joist [stringers] run the lenght of deck, but when they installed them they were notched out and put on top of the cinderblocks, and then put a 4x4 between each joist, inside the wall in the basement is a full lenght sill board though, this was a addition that was done in the 20's, the stringers are 20inchs apart, i was thinking of running the joist in the other direction to make the floor stronger. maybe this is a better idea, any thoughts? is copper flashing a better choice than lead flashing?
thank you,
jeff
Fireplace w/ TV focus point. Stone to ceiling or not? POLL 6fthook Interior Decorating 2 05-25-2011 10:02 PM
Tyvek application in crawlspace libwes Building & Construction 3 03-27-2008 12:45 PM
Door frame against stone wall elliowb Carpentry 8 12-14-2007 05:03 PM
Tyvek RickT Building & Construction 4 03-15-2007 07:06 AM
HELP! Question about Eldorado Stone EricW Building & Construction 8 10-24-2006 05:24 PM
