Putting Up Shelving In Closet But Walls Narrow - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-28-2010, 12:54 PM   #1
Putting up shelving in closet but walls narrow
I'm trying to put oak shelves up in a small closet but the width of the closet begins to narrow near the back, making measuring difficult. I'm not sure how to go about this. Any suggestions?
drewgun is offline   Reply With Quote
Old 02-28-2010, 01:31 PM   #2
I've used cardboard as a Template for the angle cut near the wall
Old 02-28-2010, 01:35 PM   #3
Rewards Points: 5,336
Interior walls are rarely square, especially in closets. There's a tool called a bevel gauge that you would use to get the angle of the inside corners. You can pick one up for about $10.00 or so. Start on one side and set the guage to whatever angle the walls are. Take that angle and pencil it on the shelf. Measure the back wall to the other side, subtract an 1/8" of an inch and mark just the width on the back edge of the shelf. Take the bevel guage and set it to the angle on the other wall. Draw the line on the other end of the shelf.
Cut the two sides of the shelf. Make sure you mark a "L" and"R" and"F(front)" on the shelves to get the correct shelf into it's correct place. Multiple shelves will require numbering as the angles will not remain constant from top to bottom.
The shelves might need individual fine tuning from front to back if the walls are not consistant.
Ron
Old 02-28-2010, 01:41 PM   #4
Thank you very much
Tags
closet , closets , narrow , shelves , shelving
Putting rigid foam on concrete walls...how to lay DriCore in this setup? ChaoticBliss Building & Construction 14 09-12-2012 06:02 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
basement walls chuckofaltrades Painting 1 10-27-2009 10:51 PM
Insulating walls for heated garage Huskie Building & Construction 5 09-19-2009 01:54 PM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 09:35 AM
