Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-27-2009, 10:45 PM   #1
putting stone vaneer on painted cinder block
Hello. I just had a question about putting stone vaneer on painted cinder block. Can you apply stone vaneer directly to painted concrete? If you can't, how would you prepare the painted concrete?
dlmont75 is offline   Reply With Quote
Old 06-28-2009, 03:47 PM   #2
Renovation Contractor
Paragon's Avatar
dl,
I would stay away from it because you have no idea of what the paint is and if it has adhered good to the cinder block.
What I would do if I were in your shoes based on the amount of information I have is apply CBU or cement backer board like Durock so that you apply a non combustible material over the cinder and secure with phillips head tapcons or you can go with the hex head tapcons however they may not countersink themselves well enough and you would then have to plan on placing grout lines where the tapcon heads are, maybe.
Then if you apply the CBU you will also have a nice fresh face to attach to. Just one thought and I believe you will receive more ideas.
Good luck and be safe.
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Old 06-28-2009, 09:04 PM   #3
Tool Geek
PaliBob's Avatar
Can you provide some more background info
  1. Location (State)
  2. Inside or Outside
  3. Concrete Block or Cinder Block
  4. Size of blocks (& the width)
  5. Size of wall (L&H)
  6. Age of Wall
  7. Coverage of the veneer (full L&H or partial)
  8. DIY or Contractor
  9. Permit?
and of course a pic or pics
There is a lot of knowledge on this forum, but we do better when there are fewer unknowns.
& Stay Safe
.....Bob Lavery
Installing a new windows in cinder block foundation monsterbash Building & Construction 1 04-13-2009 08:48 AM
Cinder block wall hangings shnfldr Remodeling 2 06-07-2008 09:26 AM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 01:00 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
