Putting A Frame On Uneven Drywall - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-01-2006, 07:55 AM   #1
Rewards Points: 123
putting a frame on uneven drywall
I put a attic ladder up but the drywall around the attic door is not even with the frame. Some of it is even but some is not. How do I put a frame around the opening with uneven drywall.
The attic ladder is 22 1/2 by 54 and the sage is in the middle of the 54. the joist sage right in the middle.
jerry1967 is offline   Reply With Quote
Old 12-01-2006, 08:04 AM   #2
Is this drywall or plaster and lath?
How much is it off?
redline is offline   Reply With Quote
Old 12-01-2006, 08:07 AM   #3
If the difference in thew drywall and frame is not extreme, you may be able to even it out with drywall compound. Feather a layer of compound by putting the drywall knife on the edge of the frame and fill in (outwards) to the ceiling. A wide knife should make it less noticeable. I am not an expert in this field so watch your post for more ideas.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-01-2006, 08:49 AM   #4
Rewards Points: 123
How much is it off?
It is drywall. The attic ladder is 22 1/2 by 54 and the sage is in the middle of the 54. the joist sage right in the middle.
Old 12-01-2006, 12:10 PM   #5
How much is the sag? (1/4, 1/2,3/4,1 inch...)
It sounds like you may want to sister on a a new joist to the two joist that support the ladder.
Old 12-01-2006, 12:27 PM   #6
I would jack up the sagging joists and then sister on a new joist to add strength to them.
Old 12-01-2006, 06:26 PM   #7
Rewards Points: 123
Ok i like the idea of jacking up the sagging joist but what does sister the new joist mean, adding another two by four to the sagging joist after it is jacked up?
Old 12-03-2006, 05:02 PM   #8
Do you know why the joist is sagging?
Is the joist cracked?
Do you have too much wieght sitting on top of the joist?
Is the joist undersized?
To sister another piece of lumber means to attach it to the sagging joist after it is leveled. You can nail it or screw to the older joist.
What is the size of the sagging joist? (2 x 6, 2 x 8, 2 x 10...)
How far does it span? (15, 20, 25 feet...)
drywall onto uneven walls? johnny331 Remodeling 5 06-28-2007 07:59 AM
Can anybody tell me if this is the proper way to frame a basement? ktwags Remodeling 2 05-09-2007 03:22 PM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
how do i put a frame on uneven drywall jerry1967 Building & Construction 4 12-02-2006 02:38 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
