putting a frame on uneven drywall
I put a attic ladder up but the drywall around the attic door is not even with the frame. Some of it is even but some is not. How do I put a frame around the opening with uneven drywall.
The attic ladder is 22 1/2 by 54 and the sage is in the middle of the 54. the joist sage right in the middle. |
Is this drywall or plaster and lath?
How much is it off? |
If the difference in thew drywall and frame is not extreme, you may be able to even it out with drywall compound. Feather a layer of compound by putting the drywall knife on the edge of the frame and fill in (outwards) to the ceiling. A wide knife should make it less noticeable. I am not an expert in this field so watch your post for more ideas.
How much is the sag? (1/4, 1/2,3/4,1 inch...) It sounds like you may want to sister on a a new joist to the two joist that support the ladder. |
I would jack up the sagging joists and then sister on a new joist to add strength to them. |
Do you know why the joist is sagging?
Is the joist cracked? Do you have too much wieght sitting on top of the joist? Is the joist undersized? To sister another piece of lumber means to attach it to the sagging joist after it is leveled. You can nail it or screw to the older joist. What is the size of the sagging joist? (2 x 6, 2 x 8, 2 x 10...) How far does it span? (15, 20, 25 feet...) |
| All times are GMT -4. The time now is 10:32 AM. |
