Put New Drywall Over Old Ceiling? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 10:31 AM   #1
put new drywall over old ceiling?
we are putting new drywall on the livingroom ceiling and wonder if the old ceiling should be removed... it is a tile style ceiling like trailor homes used to have... should we go over it or take it down?
dsbnad is offline   Reply With Quote
Old 04-29-2011, 06:37 PM   #2
if its those kinda soft easy to cut 12x12 tiles id take them down.
Old 04-30-2011, 01:46 AM   #3
timthetoolman
There are two common types of these tiles. They may have been installed by gluing to the existing ceiling surface. Or more commonly they are attached to small furring strips spaced 12" apart which run perpendicular to the support joists...which you need to screw the drywall to. If you are screwing through furring strips you need much longer screws to catch joists and support the weight of the drywall. This will be much more of a pain.
Either way...Take it down...If you don't, you are only asking for headaches. Not to mention....finding your supports to screw to through the tile and strips will be a headache. And the chances for sagging drywall, popping screws, cracked corners, will go way up if you go over existing tiles!!!
timthetoolman is offline   Reply With Quote
Old 04-30-2011, 06:38 AM   #4
Rewards Points: 1,596
Tiles may contain asbestos; might want them tested first before you start spreading asbestos throughout the home.
bob22 is offline   Reply With Quote
Old 04-30-2011, 03:16 PM   #5
to: timthetoolman.....
thank you! i did take the old celing down and so glad i did... needed to do a few repairs up there and my husband will put up canister lights now... wasn't even too messy.. i pulled the strips down and that tile came down in decent size strips also... thanks again. debra
Old 04-30-2011, 10:01 PM   #6
you will be glad you did many times in the future
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 09:50 AM
Installing Drywall Ceiling daytrepper Drywall & Plaster 10 02-10-2011 12:52 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-07-2008 11:05 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
