Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-22-2011, 12:11 PM   #1
Protecting plumbing parallel to studs
Hey all, I'm looking for some suggestions. I've reframed a wall that has plumbing running parallel along a wood stud. I'd like to save myself a lot of heartache and be able to place some type of a metal plate over the plumbing before putting up drywall so someone doesn't come along and put a nail/screw in the wall (and subsequently through the pipe). The run I need to cover is about 36-40" in length and runs right along a wood stud. I was going to use the same metal plates that we used for protecting electrical that is run through the studs, but the longest I can find are only 5" in length and but they are only 1 1/2" wide; not quite enough cover of the plumbing when it's tacked to the stud. I have some ideas of my own but I thought, with the expertise here, maybe someone has another approach. Thanks in advance!
anthony9943 is offline   Reply With Quote
Old 09-22-2011, 06:53 PM   #2
angle iron?
mrgins is offline   Reply With Quote
Old 09-22-2011, 08:57 PM   #3
Generally there's no reason to protect these pipes as long as you're careful with the wall sheeting.
Ron
B. Franklin 1759
Old 09-22-2011, 09:13 PM   #4
fabrk8r
fabrk8r's Avatar
Call your local sheet metal shop and have them cut you some 16 gauge galvanized 1" X 14.5" X 1" channels to fit between your studs.
Have them punch a few holes in the 1" legs so you can shoot some drywall screws in to fasten the panels between your studs. I make stuff like this on a daily basis for our plumbers.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 10-08-2011, 10:19 PM   #5
just make sire your drywaller is not blind and it will be fine
bluebird5 is offline   Reply With Quote
Old 10-09-2011, 06:44 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
how big is the pipe, via code all small pipes and wires must be kept 1 1/2" back from the edge of all studs so to reduce the chance of being punctured with a fastener
woodworkbykirk is offline   Reply With Quote
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
Protecting plumbing behind walls tripower Building & Construction 4 02-28-2009 12:12 PM
Pre-hung door with metal studs gmainolfi Building & Construction 4 02-07-2009 09:42 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 12:14 PM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 04:48 PM
