Proper Way To Build A Landing For Stairs - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 03:26 AM   #1
proper way to build a landing for stairs
Guys - I need some advice on how to properly build a stair landing. I'm doing a total renovation on my house and removed the old concrete stairs that led into the basement. I was thinking I would start by building the landing first since it acts as an entry way to the house via the backdoor and needs to be 3' by 3' minimum by code......maybe I'm wrong in my thinking. If not, whats the correct way to build a platform?
lslapshot is offline   Reply With Quote
Old 07-24-2012, 05:44 AM   #2
DIY staff
Rewards Points: 7,174
A picture or better description is needed.
Is this landing--below grade? Built of concrete or wood? Drainage?
Old 07-24-2012, 07:09 AM   #3
The old stairs were poured concrete and led from the basement to the backdoor then turned and went into the mudroom. So now that the old concrete stairs are gone, its just a big hole with a concrete slab. The stairs would start below grade and lead to the landing which is at grade then turn and go above grade to the house. They are interior stairs and landing.
Do I just double some 2x4's for the post then frame around the top of it with 2x6 to make a 3' box and place plywood on top? This will be a temporary landing for the construction so people can get in and out of the basement to the outside and to the house without having to climb a ladder.
Old 07-24-2012, 07:20 AM   #4
DIY staff
If they are temporary--sure--build a box frame for the deck--cover with ply and build those stairs--
If and when the permanent stairs go in--the concrete needs patching where the old cast steps were.--
Adding a couple of anchor bolts (J-bolts) might be a good plan.
Old 07-24-2012, 07:23 AM   #5
Rewards Points: 2,212
I'd add a center 'joist' to that 3' box before the plywood goes on.
mae-ling is offline   Reply With Quote
Tank will not build up more than 40lbs! 64tbirdJerry Painting 4 12-18-2011 10:34 PM
Small stairs with landing stymie222 Carpentry 11 12-11-2011 10:28 AM
What is best way to build a detached 24x24' Garage with a Basement underneath? eastpamt1 General DIY Discussions 10 12-07-2011 12:10 PM
Handyman/Contractors Can't Build Stairs? canwebuildit General DIY Discussions 13 11-11-2011 11:35 PM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 04:39 PM
