Proper Size Support Beam. - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 03:20 PM   #1
Proper size support beam.
I want to remove a 3ft. wall that is between two entrance openings.Openings measure approx.30 in. The ceiling is cathedral with no attic space above. Removing the wall will allow for wheelchair access. Will a 4x12 x14 work for this and carry load when wall is removed?
Jose Torres is offline   Reply With Quote
Old 03-07-2011, 04:21 PM   #2
Two thrirty inch openings and a three foot space between them adds up to eight feet plus the bearing surface. It sounds like you need a ten foot beam. What load does it carry? A four ply 2x12 sounds over kill but I don't have enough information and if there is a substantial load, bearing points and a engineer will be critical.
masterofall is offline   Reply With Quote
Old 03-07-2011, 04:21 PM   #3
Civil Engineer
Rewards Points: 4,942
I am confused. You say the wall is 3 feet, and there are two openings, each of which is 30 inches (2.5 feet). That makes a total opening of 8 feet, yet you propose to use a 4x12x14, which is fourteen feet long unless there is a typo in your post. So why would you use a fourteen foot long beam to span an 8 foot opening? Perhaps a drawing or a photo would help.
attaching garage loft support to 12 inch steel I beam lospinoj Building & Construction 4 09-14-2009 01:38 PM
Support pole / beam USAF Retired Building & Construction 6 01-03-2009 06:11 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
Putting support beam in basement billybarty Building & Construction 8 04-10-2008 03:14 PM
beam support cibula11 Building & Construction 20 02-16-2007 08:02 AM
