Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-14-2008, 09:19 PM   #1
proper sistering for non-bearing ceiling.
i need to replace a 2x4 in an old ceiling. the room is 17' long though. the 2x4s in there now are that long. i am wondering if i can sister two shorter ones together without having the sister board go all the way to one side. can i just use like a 2 foot section in the middle to sister them together. there is no weight on these. just to hold the drywall.
drewhart is offline   Reply With Quote
Old 08-15-2008, 08:53 AM   #2
Moderator
Termite's Avatar
Ideally, you'd use a full-length 2x4 tight to the old member when sistering to this ceiling joist. That would gain you the most strength. But, any material you add would add strength to the ceiling. I'd try to install the longest piece you can unbroken in the middle of the span, and have the shorter pieces and spices near the outside of the span. Nail the new and the old together very securely.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
sistering 2x6 ceiling joists nelsonC Building & Construction 23 11-21-2008 11:01 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
