Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-19-2011, 12:10 PM   #1
pressure treated 6x 6
Is it ok in Tennessee to put 6 x 6 post below grade into quickcrete?
Jamie Conyer is offline   Reply With Quote
Old 10-19-2011, 12:34 PM   #2
concretemasonry's Avatar
It may or may not be approved. Sticking wood in concrete is generally a bad idea, unless there is an over-riding reason. When the wood eventually rots out, you will more than likely have to remove the post and foundation unless you think you want to try the same thing again.
The best route is to use a galvanized steel attachment bolted to embedded into the concrete. Then the post is attached to the bracket that keeps it away from the moisture (especially at the ground surface), which experiences variation between wetting and drying that really tears wood apart.
Dick
concretemasonry is offline   Reply With Quote
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 09:09 AM
Pressure treated wood does or does not need to be painted???? stanlam Building & Construction 11 03-27-2011 04:04 PM
Hybrid Deck - Is Pressure Treated + Composite Feasible? kyassassin Building & Construction 4 01-15-2009 09:33 PM
How do you tell the diff btw Pressure treated and regular hardwood zhbuyi Carpentry 3 06-08-2008 08:11 PM
pressure treated or pre-stained?? farrington135 Landscaping & Lawn Care 2 05-03-2007 10:04 AM
