Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-06-2008, 08:08 PM   #1
prehung interior door hanging
do they have to be nailed on the top also? how many finishing nails are needed?
drewhart is offline   Reply With Quote
Old 11-06-2008, 08:44 PM   #2
drewhart,
You should not shim and nail your top jamb, if there is any later movement/settling of the house it will through your door out of plumb. Just work on the side jambs (hinge side first) and after the door is in, on a least the top hinge replace one of the screws with a 2 1/2" screw to secure the door to the stud behind the hinge side jamb. You should only need 3 or 4 finish nails on each jamb. When you put your trim on it will make the door more sound and secure.
Best of luck with the project, rredogg
rredogg is offline   Reply With Quote
Old 11-06-2008, 08:53 PM   #3
thanks/
Old 11-06-2008, 09:09 PM   #4
Home Remodeler
Great advice drewhart. Leave the top alone.
mikey48 is offline   Reply With Quote
More On This Topic
Learn how to paint refinished door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Learn how to caulk when refinishing door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Learn tools needed to refinish a door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Watch conclusion for refinishing a door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Learn painting tips for refinishing a door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Cutting prehung doors narrower? perpetual98 Building & Construction 2 04-14-2008 11:43 PM
Installing Prehung Interior Doors RINAIL Building & Construction 6 03-26-2008 08:49 PM
Prehung entry door gap problem 1fstws6 Building & Construction 3 03-21-2008 08:45 PM
Replace weatherstrip on prehung door? Missmargery General Discussion 2 09-19-2006 11:06 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
