PreHung Doors And Trim - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-15-2010, 02:02 PM   #1
PreHung Doors and Trim
I am just about to start installing my doors and trim in a basement finish job. There is the concrete floor of the basement,I have not picked out my carpet yet. How high off of the concrete should I install these? 1/2inch? more or less?
I was also curious what other people have used for wood to put in door frames for bifold doors and windows.
JETJR is offline   Reply With Quote
Old 01-15-2010, 02:09 PM   #2
Rewards Points: 518
For carpet I've used 1/2 inch. I just cut some scrap 1/2 drywall and put it underneath the door jambs.
As for a bi-fold closet opening, I framed mine with wood, drywalled, then used an MDF trim with baseboards to hide the track and the edges of the door for a clean enclosed look.
n0c7 is offline   Reply With Quote
Old 01-15-2010, 02:23 PM   #3
Thanks for the reply, for the closets and windows I am trying to match upstairs which doesnt have drywall. I will try and get picture tonight, but basically the whole "inner frame" of the window and closet doors has wood, then trim around it like normal. So the wood goes right up to the window and to the edge where the trim then goes down. not a window sill though. approx 4 inches in depth.
Old 01-15-2010, 05:05 PM   #4
jlhaslip's Avatar
Rewards Points: 2,884
1/2 " or 3/4" max which will allow for a cold air return in the room. you don't want the door right down on the floor. it will not let the cold air out of the room.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 01-15-2010, 07:44 PM   #5
1/2" is ok if floor is level, if not when you raise the frame on the low side to level you can get quite a bit more than 1/2.
1/2 is max imo as the tuck of the carpet at baseboard and jambs can leave you with gaps. If one side is carpet and the other a different material you will need to adjust a split jamb accordingly
Do Floor Installers Usually NOT Trim Doors? thebigsee Flooring 20 11-22-2009 09:14 AM
Help! Mismatched Trim, Doors, Windows - Paint them All??? Snowy334 Interior Decorating 12 06-30-2009 02:26 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
Trim color and interior doors..white or off white? kristinnsmith Interior Decorating 3 04-22-2008 05:48 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 10:16 PM
