Powder Puff Derby - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 02:02 PM   #1
Powder Puff Derby
Hi,
Not sure if this question belongs here but I've received help from this forum in the past, so I thought some may have some ideas.
My daughter entered a Powder Puff Derby for Girl Scouts and needs to make a race car out of wood. The wood is pine, and is 7" long x 1 3/4" wide x 1 1/4" deep. The theme she wants to make is a hair brush but I'm having trouble making the bristles.
I tried a router to make "slots" horizontal and vertical, skipping every other one with the hope of leaving a "post" to be the bristle, but they keep breaking on me when I crosscut against whichever "slot" I make first. I then tried drawing a pattern, then drilling every other "hole", but that isn't working out too well either.
Any ideas how I might make these bristles out of the block of pine?
If this question dosen't fit to this forum, I understand. Thanks
Big Bill is offline   Reply With Quote
Old 06-12-2011, 02:06 PM   #2
the Musigician
DangerMouse's Avatar
Can you post a picture? I'm having a hard time imagining what you are attempting to do.
DM
Old 06-12-2011, 02:25 PM   #3
Rewards Points: 5,336
Why not just drill holes and insert the bristles in there.
Ron
B. Franklin 1759
The Following 2 Users Say Thank You to Ron6519 For This Useful Post:
oh'mike (06-12-2011), Willie T (06-12-2011)
Old 06-12-2011, 02:42 PM   #4
DM
Hi, Here's a picture:
Old 06-12-2011, 02:45 PM   #5
Thanks,
I guess I could drill holes and insert the bristles, but I was trying to keep it as a total wood theme. I just want to give the impression of a brush, I think it would look cool if I could do that.
Old 06-12-2011, 02:53 PM   #6
the Musigician
The way you're trying to do it will continue to fail. The rotation of the router is working against you.
I would either use a table saw to do the second passes or drill and use round wooden dowels for the bristles.
DM
Old 06-12-2011, 02:57 PM   #7
Thanks DM. That's perfect advice! I'll try the table saw on the second pass and see what happens. Thank you!
Bill
Old 06-12-2011, 03:01 PM   #8
the Musigician
If you have a fine tooth blade, it'll chip out less too.... (hopefully)
DM
Old 06-12-2011, 03:09 PM   #9
the Musigician
If it were me, and the second pass worked out, I'd also attempt diagonal cuts to 'round' out the bristles too.
DM
Old 06-12-2011, 03:12 PM   #10
True.... maybe I'll try one of my hand saws first to (hopefully) control the chip out? Hey.... if I can't get it right I can always change the "theme", but I'm not a quitter so I'll give it my all first! Thanks again.
Old 06-12-2011, 03:13 PM   #11
kwikfishron's Avatar
Rewards Points: 1,004
I think even if the table saw works the pieces will be very fragile (especially with Pine), too much so for the intended use.
I like the drill and dowel idea better. You could even use toothpicks. A little bit of curve to the block wouldn’t hurt either.
kwikfishron is online now   Reply With Quote
Old 06-12-2011, 03:14 PM   #12
Another good idea!
Old 06-12-2011, 03:20 PM   #13
the Musigician
Wow, I didn't read well enough to see "7" long x 1 3/4" wide x 1 1/4" deep".
Is this just to be an ornament for a soap box derby type RIDEABLE car(t)?
Or is this the base for a small toy type car? If this is the case, drill and dowel/toothpick, yup.
Working this small of a project is hard and can even be dangerous on a table saw.
Sorry about that.
DM
Old 06-12-2011, 03:31 PM   #14
Big difference between the Soap Box and the Powder Puff class.
Old 06-12-2011, 03:39 PM   #15
LOL! Not a rideable derby. It's the same as the Pinewood Derby that the Boy Scouts have.... except for the girls:
http://www.pinewoodderby.org/
I'll be careful whatever way I do it. Thanks
Dishwasher powder instead of salt - Doh! Bottletops General DIY Discussions 0 03-03-2010 11:06 AM
gun powder Ram Set windowguy Tools 15 07-20-2009 11:08 AM
Powder or Liquid Paint Nestor_Kelebay General DIY Discussions 2 01-06-2009 05:05 AM
Popcorn ceiling has been removed, white powder on sills? daz59 General DIY Discussions 19 06-26-2007 06:28 AM
Powder Room Framing Question Not Sure Building & Construction 9 08-11-2006 06:13 AM
