Pour A Concrete Slab? - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 07:05 PM   #1
Rewards Points: 150
Pour a concrete slab?
Have anyone pour a concrete slab before? I been thinking about pouring one for my new shop if I build one. It will be a 14x18 Garage/Workshop. Wont park in a car in there thou.
CJIII is offline   Reply With Quote
Old 10-25-2011, 07:17 PM   #2
DIY staff
Rewards Points: 7,174
Lots of us have----a slab on grade would work for your area-----
Kind of like pouring a big sidewalk----
Others will give you the best advice---I am allergic to shovels---
In a nutshell----you want a 4" thick slab---and a bit thicker at the edges--(helps keep critters from digging under and rain from washing it out._)
CJ--I'm going to let someone else help you----That shovel allergy is kicking in---got to go sip some medicine.
Old 10-25-2011, 07:18 PM   #3
Rewards Points: 150
I was thinking 4'' thick!
Old 10-25-2011, 07:27 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
As it turns out---So is Obama apparently. Either that, or he just lost the damned things on one of his many trips.
The Following User Says Thank You to Bud Cline For This Useful Post:
Ron6519 (10-25-2011)
Old 10-25-2011, 07:50 PM   #5
DIY staff
There I have my medicine ---
Dig a shallow trench about 4or 5 inches deep and a foot or so wide around the perimeter--
That's the 'thickened edge'
Make your cement forms---2x 8s would be ideal---use pointed 2x4 stakes to keep it in place.
If you use thinner wood like plywood for the forms use lots of stakes---concrete will push out the forms very easily----
Make sure the forms are level and square----a water level is the easiest way to level up a foundation.
Cut off the tops of your stakes so you can drag a long board (screed) across the top of the forms)
A bed of gravel is nice for drainage but not essential--you can pour it right on the earth if you hose it down well---
Next you will need--concrete--a bull float (you can rent one) some L-shaped anchor bolts --and a pool trowel (long finishers trowel with rounded ends)
Pour the concrete unto the form-----level it out with a shovel--rake--whatever you have---
Go all the way around the form with your shovel and jamb it into the concrete to make sure you have good contact with the form (air pockets at the edges are bad_)
Level off the concrete with your screed board--this takes a helper
Next--The bull float----(might be good enough if you aren't looking for a fine finish)
Last the pool trowel---(and a scrap of plywood as a kneeing board))
Often you must wait a bit to trowel the final finish---keep testing the surface to see if it's set enough to hold a finish when stroked with the trowel.
Someone else will give you more clear instructions--Like I said --I'm allergic to trowels----Mike---
( I meant shovels--The medicine must be kicking in)
Old 10-25-2011, 08:18 PM   #6
kwikfishron's Avatar
Rewards Points: 618
Practice on the sidewalk first.
I donít recommend DIY garage slab for a rookie.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
woodworkbykirk (10-27-2011)
Old 10-25-2011, 08:35 PM   #7
DIY staff
Ron, I know CJ---He will do this---and learn from the experience---and live with it good or bad---That's CJ---
Old 10-25-2011, 08:56 PM   #8
Rewards Points: 150
Been thinking about hiring someone to help me with the slab.
The Following User Says Thank You to CJIII For This Useful Post:
oh'mike (10-25-2011)
Old 10-25-2011, 09:12 PM   #9
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Are you close to the river?
Are you in a flood plane?
Andy.
AndyGump is offline   Reply With Quote
Old 10-25-2011, 09:15 PM   #10
Rewards Points: 150
I have canal going right besides my house. My yard is low so water sits up in the yard.
Old 10-25-2011, 09:17 PM   #11
DIY staff
You will learn a lot if you hire someone who is experienced------Knowing when the cement is right to smooth out is hard to figure the first time----to wet and it won't trowel out----to far along and ---you're not happy either----
Old 10-25-2011, 09:39 PM   #12
AndyGump's Avatar
Rewards Points: 684
My questions are geared toward establishing if you are in a flood prone area and if your local Building Department will want you to build accordingly.
If in a flood plane you may have to raise the floor level, be on a crawl space for a work shop, raised pad for a garage, etc.
If building garage you may need a stem wall with footing, anchors and/or hold-downs, etc.
Give us more info on what it is to be.
Andy.
Old 10-25-2011, 10:43 PM   #13
Rewards Points: 150
I am not in flood plane, we dont have many floods. The river is downtown.
Old 10-26-2011, 06:54 AM   #14
Rewards Points: 106
Just me, but I would not build any type of structure without at least a rat wall, and, regardless of that, you will definitely want help with the slab, hired or otherwise.
Old 10-26-2011, 11:14 PM   #15
Too Old
If water sits in your yard, you are next to a canal, how is this good?
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
To Remove Concrete Slab in Bathrooms? fletch7 Remodeling 7 08-05-2011 08:58 AM
Concrete Slab dgaz Building & Construction 5 11-14-2010 10:50 AM
Removing basement tile and pouring concrete slab tondar Building & Construction 12 11-05-2010 11:28 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
