Posting Tapered Cedar Siding - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2011, 02:37 AM   #16
Contractor - Renovations
fungku's Avatar
Originally Posted by amakarevic View Post
what should i use as furring strip ? can i buy it under such name at HD/lowes or do i need to makeshift one ?
thanks
you can usually buy PT or cedar strapping... or just makeshift...
fungku is offline   Reply With Quote
Old 02-25-2011, 07:34 AM   #17
mem
Rewards Points: 156
To get the same angle on the first course of siding as the rest, you would just rip the top edge off a piece of siding and use it as your starter strip. Pre-drill it and nail at or just above the bottom edge of the sheathing. The first course of siding should overhang the starter strip by a half inch or so for drip. Depending on the layout, with any luck the leftover piece of lap you have from cutting the starter strip can be used as the top course of siding.
Realistically tho, a small difference in the angle won't be noticeable except maybe at the corner boards. So if you're tight on materials or don't care to figure the layout, PT or cedar strapping is fine to use. Since the starter strip won't be seen, you can keep everyone happy and use galvanized nails on it.
mem is offline   Reply With Quote
The Following User Says Thank You to mem For This Useful Post:
amakarevic (02-25-2011)
Old 02-25-2011, 08:42 AM   #18
This is the norm
mrgins is offline   Reply With Quote
Old 02-25-2011, 12:35 PM   #19
fungku's Avatar
Originally Posted by mrgins View Post
This is the norm
I have done that if I know I will be ripping down a piece anyway, but cedar siding isn't exactly cheap.
Old 02-25-2011, 12:42 PM   #20
mem
Rewards Points: 156
Agreed. If he figures the layout first, he'll know if he can do it.
Solid Stain on Cedar Siding Researcher Painting 1 08-08-2010 10:11 PM
Asphalt shingle siding over cedar shakes Catguy Building & Construction 1 04-05-2010 09:10 PM
Installing fiber cement siding over existing cedar siding heron Remodeling 3 07-24-2009 11:17 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 07:06 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
