Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-18-2011, 07:56 PM   #1
Question
posting tapered cedar siding
i just acquired some 11/16 x 8" cedar siding planks that i plan to side my shed with. the 11/16 is the thickness at the thick side and it tapers to pretty much 0 on the other side.
my idea was to post them thin side up but my dilemma was whether to overlap the last inch with the thick end of the next row or to actually trim it off and have no overlap. i would like to avoid having the last inch on the thin side exposed because i think it's fragile.
the advantages of trimming the last inch off is to make the surface thinner, i.e. more even and i think it would be easier to hang. but that could potentially leave or, with time, develop gaps between rows whereas overlapping would make sure there is no gaps.
thanks
Old 02-18-2011, 08:11 PM   #2
you have to lap it or th wood behind it will rot due to water infiltration. The idea behind lapping it so the water runs down on piece and on to the next rather than behind the next piece. Lap it and use thicker corner boards if there is an issue with it sticking out
bluebird5 is offline   Reply With Quote
The Following User Says Thank You to bluebird5 For This Useful Post:
amakarevic (02-19-2011)
Old 02-18-2011, 09:01 PM   #3
Contractor - Renovations
fungku's Avatar
You gotta lap it.
fungku is offline   Reply With Quote
The Following User Says Thank You to fungku For This Useful Post:
Old 02-18-2011, 10:34 PM   #4
Moderator
Scroll through some of these books that have "Preview" under the title, nails, doors, sheds, bevel siding; http://www.google.com/search?tbm=bks...G=Search+Books
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 02-19-2011, 02:29 AM   #5
Question
so when it says "nail must penetrate solid wood 1.5 in" does "solid wood" mean just the 2x4 stud or the stud + sheathing, in other words is OSB sheathing considered "solid wood" ??
because when i went to the lumber yard to get the cedar, they also sold me 2" ring shank nails to use with it but that will go 1.5" in 2x4+sheathing, not just 2x4.
Old 02-19-2011, 02:45 AM   #6
fungku's Avatar
Solid wood includes sheathing + blocking or studs.
Old 02-19-2011, 06:08 AM   #7
did they sell you Maze nails?
mrgins is offline   Reply With Quote
Old 02-20-2011, 12:53 PM   #8
Bulls Eye Nails
Old 02-22-2011, 10:22 AM   #9
mem
I would make sure to use stainless nails too. Other types can stain your wood as it weathers.
mem is offline   Reply With Quote
The Following User Says Thank You to mem For This Useful Post:
amakarevic (02-25-2011)
Old 02-22-2011, 01:55 PM   #10
man just get some galvanized nails ling enought to go through the siding and into the stud. some 6's or 8's would be fine i don't know what a maze nail is or a bull's eys and don't care any you shouldn't either. GALVANIZED AT LEAST 1.5 INCHES thats all that matters
Old 02-22-2011, 02:09 PM   #11
mem
I'm sure galvanized nails would hold the siding nicely, as longs as you don't mind the black streaks running down the boards from every nail hole in a few years. Aluminum nails would work nearly as well as stainless, and would be less expensive too.
Old 02-22-2011, 02:30 PM   #12
Yeah, that should last long enough til the customer's check clears, right?
The Following User Says Thank You to mrgins For This Useful Post:
Old 02-22-2011, 02:30 PM   #13
fungku's Avatar
Originally Posted by tomstruble View Post
use stainless only,they are worth the added cost...
Listen to Tom you should. The siding master he is.
I think HDG would do you well for quite a while, but other types of galvanizing is not recommended. Still your best choice is always stainless.
from Western Red Cedar Lumber Association:
Stainless steel nails are the best choice, especially if the siding is to be finished with transparent or semitransparent stain. Use No. 304 stainless for general siding applications and No. 316 for seacoast exposures.
Hot-dipped galvanized as per ASTM A 153, aluminum and stainless steel fasteners are all corrosion-resistant and all can be used to fasten Western Red Cedar. Other types of fasteners (including electroplated and mechanically galvanized) are not recommended. They can rust and disintegrate and react adversely with the natural preservative present in cedar resulting in stains and streaks.
Old 02-22-2011, 07:25 PM   #14
STAFF
BigJim's Avatar
Originally Posted by fungku View Post
Also notice the nails do not go through the top of the next board down. The wood will expand and contract and if nailed at top and bottom the board can split. The illustration posted by fungku is the correct way to nail the siding.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Tom Struble (02-25-2011)
Old 02-24-2011, 03:52 PM   #15
Question
what should i use as furring strip ? can i buy it under such name at HD/lowes or do i need to makeshift one ?
thanks
Solid Stain on Cedar Siding Researcher Painting 1 08-08-2010 11:11 PM
Asphalt shingle siding over cedar shakes Catguy Building & Construction 1 04-05-2010 10:10 PM
Installing fiber cement siding over existing cedar siding heron Remodeling 3 07-25-2009 12:17 AM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
