Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-09-2009, 11:23 AM   #1
Angry Post caps
Do not use the Verand product post caps on their Veranda product post sleeves.
The caps, although, nice looking, allow rainwater to sip into them and rot the 4x4 posts.
I called Veranda and they suggest I go to Home Depot and try to get the caps replaced. Why would I want them replaced? The replacements will have the same problem
marshallzulu is offline   Reply With Quote
More On This Topic
Now we are going to show you how you can attach a new picket fence to a pre-existing picket fence. Now what we have done here is we have taken this pressure treated 2x4 and we have simply nailed it to a pre-existing 2x4 foot pressure treated frame. Now... Read More »
This is my pressure treated 2x4 used for the framing of your picket fence. Now on this picket fence the frame, the bottom, and the top are pressure treated 2x4's. Now since this is a 24 foot long fence we will need 6 - 8 foot 2x4's. Now when you measure... Read More »
My name is Gail Thompson, owner and operator of Gardens to Grow in Pacific Grove, California. We are here today to instruct you on how to install a picket fence. Of course you will need some concrete mix. Now this is a ready to use concrete mix that you... Read More »
Now this is your picket for your picket fence. It is a 3 inch wide by 1 inch depth. For ease of application what you can do is use another picket as a spacer. Again this is 3 inches, you need 1 inch between each picket. Take your next picket, put it... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation on this home. So what I want to talk about here for a minute is the working R-Value of a wall. What I mean by working... Read More »
6x6 Cedar post rot stanltod Carpentry 2 06-21-2009 06:54 PM
Post Caps needed. Clutchcargo Building & Construction 2 06-15-2009 09:22 PM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 4 03-22-2009 09:15 PM
How To: Post Nathan Site Help and Suggestions 0 07-04-2008 05:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
