Possible Gazebo Off My Existing Deck - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 09:48 AM   #1
possible gazebo off my existing deck
I just added some rails and a bench to my existing deck. i is about 3 feet off of the ground...now my wife wants to add a short walkway to a gazebo area. we saw a few kits for these but i was wondering if i should just build the gazebo myself using longer 4x4's anchoring them into the concrete. and building the gazebo around them or build a platform and build the kit on top of that platform. my concerns are that my existing deck it 7 years old and has settle but the new construction would still need to settle. would it be wiser to have just the platform settle with the separate structure on top of that or have the whole gazebo settle as one?...another thought that i had was to make the short walkway like a wheel chair ramp down and have the gazebo kit on the ground....any opinions would be greatly appreciated....i want this to look great and last long.
rollinastang is offline   Reply With Quote
Old 05-21-2011, 05:38 PM   #2
Household Handyman
Rewards Points: 1,408
I don't know about the codes for Ohio, but the railing on that deck would pass code here. There would be too much spacing between each rail. Here it would require no more then 3" between each rail. Supposedly to prevent a child's head from getting through these whether you have children present or not.
Old 05-21-2011, 10:28 PM   #3
In a little over my head
Rewards Points: 706
I really like the style of that railing. Nice looking. Unfortunately, it woouldn't pass code here either. Gotta have no gaps larger than 4" and no horizontal rails that would entice little kids to climb the "ladder". But that wasn't your question.
At this point, I'd build the gazebo on a seperate deck, on seperate footings. Connect with a nice wide "ramp". That would allow a little movement between the two. As for building the gazebo itself, are you talking about a six sided gazebo? That is a lot of fancy cutting. I've always been intrigued with the idea. But, depending on your level of experience, I'd think about a kit or at least a good plan. (And I never use a plan.)
ratherbefishing is offline   Reply With Quote
Old 05-23-2011, 04:52 PM   #4
thanks for the compliment on the railing i liek your idea of the wide ramp that makes total sense. yes i am talking about the 6 sided gazebo. my skill level is pretty good but i am not pro or anything so leaning toward the kit is probably best for me!
Cedar deck help mickbiv Painting 11 08-08-2013 10:21 PM
Joining deck roof with existing roof Badur Roofing/Siding 1 03-27-2011 03:47 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 11:15 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 01:28 AM
Best way to attach low level deck to existing concrete slab. fulghumd Building & Construction 4 03-11-2010 07:45 PM
