Porter Cable Framing Nailer Problem - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-03-2008, 09:25 PM   #1
Question
My nailer got me today... through the finger... It double shot nails... the first nail went in the 2x4 then the nailer bounced up and before I could let go of the triger it came back down hitting a clancing blow and shot into my finger... It has been double shooting nails alot and I don't know why... It is rated for 70 - 100 lbs of pressure... I have it set about 80 lbs... Anyone know what stupid thing I am doing or not doing??? HELP
rutilio is offline   Reply With Quote
Old 08-03-2008, 09:35 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
It sounds to me you are keeping your finger on the trigger and bouncing the nailer off the wood. The correct way is to push the nailer against the wood and then depress he trigger. I know!! we all do it but try the above way until you get use to the nailer.
Old 08-03-2008, 09:42 PM   #3
remodeling pro
Just my opinion, but all of the PC guns seem to have some sort of strange center of gravity that makes them bounce easy. I have a PC coil nailer that we use for cement siding, and it also bounces and double fires pretty regularly. I don't own any pc stick framers, but have picked up and shot some on jobs and immediately got the same feeling about them.
troubleseeker is offline   Reply With Quote
Old 08-03-2008, 10:53 PM   #4
Registered User
Termite's Avatar
You might try to find out if a sequential trip trigger kit is available for them. They're the type of trigger that will not allow you to double fire.
Old 08-04-2008, 10:37 AM   #5
Oldguy
Rehabber's Avatar
The FR350A has a selectable trigger, (bump or sequential fire) on a piece of scrap wood,hold down the trigger and then "bump" the nose of the gun. If it fires, you are in bump mode. Turn the button on the trigger 180 degrees and retest the same way to ensure it is in sequential mode.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 08-04-2008, 08:10 PM   #6
Unhappy
Porter Cable nailer problem
I will check to see if my nailer has a sequencial trigger setting.... I am sure right now it is in the bumb mode.... Unfortunately I don't use it for nailing sheeting ply to rafters or studs... I use it more for building tables or projects with 2x4's... which means I really need a one shot at a time nailer... would it help to turn up the pressure on my compressor??? Thanks for your comments... any information is very helpful... my hands are sore... LOL
Old 08-04-2008, 08:58 PM   #7
So you got your tetanus booster shot?
Old 08-06-2008, 10:38 PM   #8
No, does anybody really do that everytime they get gouged by a nail????
Old 08-07-2008, 06:23 AM   #9
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
New nails.....no.
Very Old Rusty Nail with a serious puncture = yes.
- Build Well -
Old 08-07-2008, 08:23 AM   #10
Originally Posted by AtlanticWBConst. View Post
New nails.....no.
The puncture wound is where these germs live; they can't stand air.
Gouge = air = no lockjaw.
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 11:17 AM
Porter Cable FR350A Jams With Grip-Rite Fasteners BigJimmy Tools 4 11-11-2007 01:26 PM
Framing Nailer (Porter Cable) Renovator Tools 2 04-26-2006 06:43 PM
2hp / 6gal Compressor w/ framing nailer scarrell Tools 4 04-24-2006 08:34 AM
