Porter Cable Dovetail Jig - 1/4" Shank Router Bit - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-21-2014, 12:35 PM   #1
Porter Cable Dovetail Jig - 1/4" shank router bit
I was wondering if anyone has used a bit with a 1/4" shank on the porter cable dove tail jig?
I want to buy the jig, but my router only takes 1/4" shanks and the jig comes with 1/2" bits. I don't do this enough to warrant buying a second router.
The bit size that comes with the jig is 7 W: 17/32" H: 3/4"
Can I just purchase a bit with those specifications and I should be good to go? It seems like it should, but I was wondering if Porter Cable had something special about their bit for the jig that might make it different?
I found a bit for sale at whiteside and at MLCS that matches the specs.
ryan112ryan is offline   Reply With Quote
Old 07-21-2014, 12:47 PM   #2
Rewards Points: 13,446
I'd be looking for a 1/2 collet for your router.
1/4 shanks are for light duty trimming jobs, not heavy material removal.
Old 07-21-2014, 12:51 PM   #3
Rewards Points: 144
You'll be fine with the 1/4" shank bit and the PC jig.I prefer the Whteside cutters to the MLCS.As long as the specs match you'll be fine.The 1/2" shank bits will have less chatter but it won't be a problem as long as you don't try and feed it to quick.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
PaliBob (07-21-2014)
Old 07-26-2014, 12:36 PM   #4
I wanted to do an update for others that are looking for a 1/4" shank bit for the porter cable dovetail jig. I purchased this bit:
Whiteside D7-530 Replacement Router Bit Dovetail 1/4" Shank 17/32" D x 7 Degree Item #148965
You can find it over at whiteside [dot] com for about $24 + shipping.
I just got it and did a test piece with it and it worked very well. I'm sure you do get some "chatter" from it only being a 1/4" bit, but I felt that the results was very good for me as a DIYer. If I was a pro, maybe, but then again, if I was a pro, I'd have a 1/2" bit router.
Hope this helps others.
Old 07-26-2014, 08:57 PM   #5
Rewards Points: 3,520
If you ever have a 1/4 Inch bit snap on you while your working, you'll know the difference and go to 1/2 inch in a heartbeat.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
del schisler (07-27-2014)
Porter Cable FR350 bad driver blade? timp Tools 6 05-20-2009 05:04 PM
Porter Cable Combo kit JFD140 Tools 4 08-11-2007 07:57 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
Porter Cable BN 200A helpless handyman Carpentry 1 05-28-2007 01:06 PM
Framing Nailer (Porter Cable) Renovator Tools 2 04-26-2006 06:43 PM
