Originally Posted by Kurt1968
I was going to use a 2x6. Thats what im using for rafters. I think the HAP is 4 1/2 like you said .
Kurt,
Since your using 2x6 commons you have to use the next size bigger for the hip structurally. Uae a 2x8.
When you mark the length of your hip at the outside corner of the building and draw you plumbcut, you have to come in half the thickness of the hip and make another plumcut mark and mark the HAP cut from that mark and then scribe the level seatcut.
This will make the top of the hip plane in at the plateline the same HAP cut height as the common HAP cut because the hip travels at 45° from the corner and if you mark the HAP cut at the outside corner it won't be the same height at the plateline causing the fascia to rise up at the corner.
Here's a drawing I did years ago showing you the plan view of the outside corner and how the hip travels at 45° and has a run (half thickness of hip) and rise. It will show you how to mark the HAP cut.
