Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-09-2011, 02:34 PM   #1
Porch remodel
I am lowering a ceiling in my porch. I have to span 12 feet and hang dry wall. What size ceiling joists do i need?
gunlake is offline   Reply With Quote
Old 01-10-2011, 01:37 PM   #2
Drywall contractor
Porch remodel
Best bet would be to check with your local building dept., but I would think 2"x6" @ 16" o.c. would be sufficient for 1/2" regular. Is this going to be an enclosed porch? If it's just going to be screened, I'd highly recommend using wood rather than drywall....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-10-2011, 08:26 PM   #3
Porch remodel
right now is it open up to the rafters, or will you be hanging another ceiling off the existing ceiling?
if rafters are exposed, you can use 2X4 or 2X6 with a vertical piece of wood (2X4 or even 3/4" plywood) lapped onto joist and rafter to break the span.)
i would do this regardless of framing member, as 12' is a long span.
if hanging off existing ceiling, it all depends on what's up there...
i would also discourage use of sheetrock on a porch.
wombosi is offline   Reply With Quote
Old 01-23-2011, 10:27 PM   #4
Porch remodel
a 2x6 is allowed to span a maximum of 12 feet
bluebird5 is offline   Reply With Quote
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 01:14 PM
Leaking Roof Where House Meets Porch tazmajazz Roofing 7 08-25-2010 07:18 PM
3 Season Porch Remodel Biyobe Remodeling 8 04-10-2010 08:27 PM
How to Winterize Porch subdude Remodeling 0 02-04-2010 10:00 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 07:54 AM
