Porch Post Support - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-05-2010, 09:13 PM   #1
Porch Post Support
I'm remodeling my porch which has wooden posts on a cement slab. I've used these particular supports before, but can't seem to find the same type. They are metal plates the size of the post bottom with four legs on the bottom to keep water from the bottom of the post. Does anyone know what these are called or where I can find something like this???
lcoxrail is offline   Reply With Quote
Old 08-05-2010, 09:28 PM   #2
Superintendent
Mudpad's Avatar
They are post anchors made by Simpson. You can buy at Lowes or HD or google simpson anchors online.
Mudpad is offline   Reply With Quote
Old 08-05-2010, 09:28 PM   #3
Old School
Willie T's Avatar
Try Googling: Simpson Post Base
Willie T
Old 08-06-2010, 06:55 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Welcome to the Forum
I think you are looking for a standoff post base similar to:
AB/ABA/ABE/ABU Adjustable and Standoff Post Bases
Note, The Big Box stores carry very few post bases compared to all the possible configurations. To find a local Simpson Dealer try:
Dealer Locator - United States
Note that Link will show HD and even small Hardware stores that sell only a few Simpson products. To find the major Simpson Sources you might have to expand the "Search within window"
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-06-2010, 09:31 AM   #5
Household Handyman
Rewards Points: 1,408
We call them "post chairs" in my area. They are bought at local builder supply store, not a big box store. The one's I am familiar with are a cast aluminum product as you described. The post/square column sit on top of the "chair", which is actually bolted to the post from the bottom, then there are four legs maybe 1/2" to 3/4" high the "chair" sits on for water to drain out from under. Try a builder supply store, not a Lowe's or HD type store. Maybe even an online search. Good Luck, David
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
Attaching Porch Post to Foundation Earnie Building & Construction 4 03-15-2010 09:38 PM
Moving a support post RaH Building & Construction 5 03-07-2010 09:48 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 07:14 AM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 10:33 PM
