Poplar Vs Pine For Sliding Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 05:49 AM   #1
Rewards Points: 12
Poplar vs pine for sliding door
Hello all,
I need to make two sliding walls for a closet, to be hung on bypass track. The track is designed for 3/4 inch thick doors. I was going to assemble each door as a flat panel insert, using pocket screws. Each door will be 9'x4'. The panels will be 1/4" mdf. The rails and styles will be 1"x4". Which wood is best for this size door? Pine or poplar? Other option? The finished doors will be painted.
Thank you in advance
dincanta is offline   Reply With Quote
Old 06-15-2012, 06:05 AM   #2
DIY staff
Rewards Points: 7,174
9 feet x4 feet?---Those will not stay flat using 3/4" stiles and rails--sorry---
Get heavier track and go for 1 3/8" minimum stiles and rails--I would use a glued up section made of two 1x4s---Poplar or fir would be safe choices--use the best straight grained,clear product available.
I suggest tennoned joints --glued--those pocket screws will allow the stiles to roll out of plane on a door that large.
BigJim (06-15-2012)
Old 06-15-2012, 06:59 AM   #3
Rewards Points: 12
Thank you mike. That was my fear. If I changed the height to 8', could I keep the thickness 3/4" by ripping some type of engineered wood like ply of mdf, to make the rails and styles? My concern with mdf is it might bend at 8' lengths but I could be wrong.
Old 06-16-2012, 05:38 AM   #4
DIY staff
Wood will twist ---3/4 inch is just to thin---even steel or aluminum would be floppy in those sizes.
Old 06-16-2012, 11:30 AM   #5
Too Short? Cut it Again!
I think I would be inclined to put support midway down the 9 foot dimension also. Just cut panels for top and bottom sections.
Maybe I am old school but I think I would use 1/4" tempered masonite before MDF that thin for the panels. I am not sure I could make a strong argument as to why though.
And I too would add some sort of joinery---tennons would do it---and not rely just on pocket screws and butt joints.
interesting patio door problems....please help. diybrad Building & Construction 6 11-20-2011 11:52 PM
Poly pine door or not? Oh-Fudge Carpentry 4 10-14-2011 08:50 PM
Can I shorten a Fiberglass door. rjniles Building & Construction 6 12-08-2010 12:57 PM
oak trim w/ pine door aleciadooley Carpentry 5 04-04-2010 08:32 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
