Pony Wall/Half Wall & Ledge Wall??? How To & Correct Terminology - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 07:11 AM   #1
Rewards Points: 150
Pony Wall/Half Wall & Ledge wall??? How to & Correct Terminology
So I want to put a half wall the the entrance to my living room from the front door. I also want to build a 6" deep shelf wall (?) on one wall. Let me see IF I can explain this shelf wall better?? Basically it will be a shelf (for pictures, knick knacks, but will be a wall. Make sense? My thought is 2x4 framing for both walls, but suggestions are MORE THAN WELCOME. On both walls should I install luann (for stability) before the sheetrock? Or would the sheetrock be good enough?
THANK YOU
Evil Scotsman is offline   Reply With Quote
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
