Polyurethane Treads BEfore Applying? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-30-2014, 10:48 PM   #1
polyurethane treads BEfore applying?
Im currently replacing the treads and risers (risers will be painted).
two questions...Im assuming I can just poly the treads WIThOUT staining them correct? and secondly can i poly them prior to installing them? I was thinking of polying them right up until the last coat, i could then install them and apply the last coat...what do you all think? (I would already have them cut to fit prior to polying them, obviously) Im using red oak btw.
supermatt is offline   Reply With Quote
Old 03-30-2014, 11:52 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
No need to stain if you like the look of only poly. No reason not to do all coats prior to install.
iminaquagmire is offline   Reply With Quote
Old 03-31-2014, 07:25 AM   #3
Rewards Points: 13,752
Make sure to sand the treads before the poly, if not you may see lines across the board from the planner.
Old 03-31-2014, 09:42 AM   #4
Thanks all!
Tags
polyurethane top coat , stair treads , stairs , treads
Applying Polyurethane to Wood Panel Walls nphill85 Painting 2 09-27-2013 03:56 PM
Should I replace wall skirt when installing new retro treads on existing stairs hkeiner Carpentry 12 02-15-2013 07:21 PM
replaced stair treads dhungy Flooring 5 06-20-2012 10:21 AM
Air Bubbles after finishing Stair Treads with Polyurethane water_cutter101 Flooring 1 09-08-2009 05:20 AM
Applying polyurethane with a pump-up sprayer handymanII Painting 3 10-17-2007 03:01 PM
